Carbs, pressure reg, Megajolt, and other bits for sale.....
As I'm now well under way on my Megasquirt Conversion, I have the following up for grabs.......
Twin Weber DCOE 40's, and filter king pressure regulator - New in 2000 (so are the newer type) - 34mm chokes, 125 mains, also come with Weber
40mm trumpets, Misabs,Braided link hose, fitting washers, Trumpet clamps, and even the throttle linkage - £295 plus £5 Postage
Carb pic
Pressure reg and filter
Machined 32mm coolant sensor adaptor (10mm thread), surpless to requirements - Never used (apart from screwing the sensor) - £10 (cost £15), with
coolant sensor (used) £15. - Free postage
Coolant sensor
Set of 8 Stainless Jubilee (origional ones) clips - 35 - 50mm - Brand new, perfect for TB or bike carb attachment - £12 - Free postage
Clips
Megajolt V3 - Comes with loom, TPS, Coil pack, Software / manual disc, serial cable, EDIS - Basically everything you need apart from the Crank sensor
(will be removing this from car on the weekend) - £90
U2U me if you need any other details.
Paul.
[Edited on 31/1/08 by Jenko]
