Author: Subject: Bike carbs for sale, manifold & other bits.
Danozeman
posted on 1/3/09 at 10:18 AM Reply With Quote
I have 2 sets of zx9r carbs for sale.
First set ZX9R b1 carbs. As they came from the bike with backplate and trumpets VGC. £75 posted.
Image deleted by owner
Second
ZX9R C carbs. These have a tps on the side. VGC. No back plate or trumpets but can be got from ebay for not alot. £85 posted.
Also i have a home made zetec inlet manifold which i made for the ZX9R C carbs. Not the neatest welding job but works. Looking to recover the cost of the plate so 25 quid posted. The plate cost me 20 quid plus post from shortrack. Would look good painted.
Also i have a sierra collapsable collum bit. less the actual colum. This comes with bonnet pull, steering lock and key etc. Good condition but the key is very worn. With a new key will be perfect. Christ knows what this is worth?? £15 posted??
SOLD
All offered here before ebay gets them. Open to offers from fellow builders they need to go. You can collect from Stowmarket suffolk or i should be at the Diss meet next week.
Iv got a selection of smiths gauges aswell which ill put up later.
[Edited on 1/3/09 by Danozeman]
Dan
D Beddows
posted on 1/3/09 at 05:16 PM Reply With Quote
£15 posted for the collapsible column section? if so I'll have it
rpm
posted on 1/3/09 at 06:59 PM Reply With Quote
if you've got an electrically driven smiths style speedo i'd be interested
Charlie_Zetec
posted on 25/3/09 at 02:07 PM Reply With Quote
Hi fella, bit new to all this, but I've got an 1800 DOHC Zetec engine I'm building up. Will the manifold and carbs you've got for sale fit on?
If so, I'm definately interested. Based in Chelmsford, but always around the Colchester/Ipswich area. Drop me an e-mail on bigcharles82@hotmail.com or call/txt me on 07740-542280.
Look forward to hearing from you!
DarrenW
posted on 25/3/09 at 02:24 PM Reply With Quote
Charlie - may i suggest that you get the carbs with the TPS already fitted. This will make connecting to megajolt a lot easier.
i cant believe how you have fell in lucky.
I managed to find a back plate with trumpets quite easy for my ZZR1100's. I was told using the original bike trumpets is a good idea for smooth air flow. As said shouldnt cast you much.
Charlie_Zetec
posted on 25/3/09 at 05:15 PM Reply With Quote
Do i want to use a megajolt or megasquirt system with them? I'm currently watching both on ebay and looking at new prices, but unsure which one to go for.
Think my estmations for keeping this project low(er) budget and simple have gone out the window!
Stuart_B
posted on 26/3/09 at 02:48 PM Reply With Quote
hi, what gauges have you got for sale?
thanks
stuart
Charlie_Zetec
posted on 30/3/09 at 03:45 PM Reply With Quote
u2u sent re. manifold
posted on 30/3/09 at 06:56 PM Reply With Quote
Megasquirt is for fuel injection. since these are carburettors you only need ignition control which is what Megajolt gives you.
