Author: Subject: SVA Indicator Extensions and Mini Indicators
Guinness
posted on 26/5/09 at 07:24 PM Reply With Quote
For Sale - 1 pair of used mini Cat Eye style indicators, with orange lenses and 23w bulbs. Lenses are marked E11 (OK for UK use).
Will be fitted with a new pair of 23w orange bulbs before dispatch. This should ensure that 1 they work when they arrive with you and 2 your indicators flash at the right rate.
Complete with stainless steel extension bars. The bars are polished stainless tube, but the ends are brushed finish as there was some discolouration when the lads welded them up for me.
The bars made sure that the indicator lenses were less than 400mm from the widest point of my Indy when they were fitted into the recess in the Indy nose cone.
Overall length is 215mm from the end of the tube to the end of the indicator. It is 195mm from the end of the tube to the centre of the lens.
The stainless extensions are 150mm long.
I passed SVA at Newcastle with these on. Can't promise they will pass IVA!
The little screws holding the lenses in are rusty and one of the black plastic casings has deformed very slightly due to heating. Should press back into shape with a heat gun.
£15 posted sound reasonable?
Mike
