kingster996
posted on 26/10/16 at 02:49 PM |
FS: Fuel Rail and Injectors and other Zetec bits
I have a set of new unused injectors complete with fuel rail, regulator and wiring harness from a 2004 Blacktop Zetec (new crate engine).
This has inlet and return feeds so will be good for conversion to injection.
£35 delivered mainland UK
Also have an ST170 manifold that they should fit into (not actually checked though!) - have the fuel rail for that too (used but tatty)
There's a few more new Focus bits lying around like clutch (won't fit type 9 etc FWD only) and pressure plate, single throttle body,
throttle pot, idle control valve - as well as a complete std sump (alloy and steel parts) that would be ideal for a chop job as it's obviously
very clean being unused :-)
Will upload pics if anyone is interested.
I used to be indecisive, but now I'm not so sure
chris
posted on 26/10/16 at 11:03 PM |
could i have the zetec fuel rail bits please and the sump and throttle bits and idle valve
[Edited on 26/10/16 by chris]
kingster996
posted on 27/10/16 at 08:51 AM |
OK, had a couple of U2U's about the various bits, so will reply and give 'dibs' based on time sent in order to be fair
kingster996
posted on 27/10/16 at 09:30 AM |
OK - here's prices for the other bits etc
Full sump and throttle body (with pot) sold to Daveg
Chris has dibs on the Fuel Rail (with injectors, loom etc) and idle valve
Individual prices based on the lower end of what I can see on ebay - idle control valve £25 plus post.
ST 170 bits used from a 90k motor:
I have a full inlet with manifold and fuel rail (no injectors) and throttle body. Complete for £50 plus post or can split (manifold can be used for
ITB conversion)
Also have an alternator £30, aircon pump £10, power steering pump £10 (all plus post)
Postage (mainland) should be £5 to £10 with insurance depending on size/weight
If I find any more bits, will add them here.
[Edited on 27/10/16 by kingster996]
kingster996
posted on 27/10/16 at 07:49 PM |
Chris - sent you a couple of U2U's - I have someone else who is after the fuel rail and injectors - so if I don't hear back soon,
I'll pass them on to him.
Chris
kingster996
posted on 27/10/16 at 09:54 PM |
Fuel rail and injectors sold
[Edited on 28/10/16 by kingster996]
