Author: Subject: Gtir backplate for jenveys
Shooter63
posted on 22/11/18 at 06:52 PM Reply With Quote
Somebody may be able to use this, it's a gtir backplate for jenveys/Webers with a 93mm spacing between units ( centre to centre) but it's been cut for a FWD set up as in the inlet of the gtir top will face the bulkhead, I suppose if you are building a mid engine type car it may by of some good, or if you weld up the mounting holes and re-drill it would work in RWD
£40.00
Shooter
