Author: Subject: shifter cable for sale OEM part
locoboy
posted on 10/7/08 at 02:44 PM Reply With Quote
I have got a shifter cable that would be spot on for a bec installation.
It comes complete with a lever and can be made to fit a locost (or other) chassis very easily.
Here are the dims
Overall length 130cm
width of flat but that mounts to chassi 80mm x 80mm
lever length 140mm
mounting point for the cable is 75cm from lever end
17mm hole req for bulkhead fitment
there is a small bit that has chaffed through the casing to to steel outer braid but it still shifts nicely.
cast ally pivot housing.
Image deleted by owner
£45 posted or it will end up on ebay.
Locoboy
