Hugh_
posted on 23/11/08 at 03:24 PM |
Clearout (some bits FOC)
Please do NOT U2U me, I cannot receive them because of the _ after my username. My email is hugh_gabriel (at) msn.com
Collection from near Cranbrook, Kent
Locost Cycle Wings- First Dibs to Ben_Copeland
Aluminium, 205 mm wide externally, 195mm wide internally, drilled. £5 collected, will not post.
M16 brakes
* M16 Calipers & discs, ~4mm on pads (unknown type), discs ~9.7mm thick. Paint slightly peeling from calipers. Both have copper and flexi
(only 1 shown). £35 or £45 posted First dibs to Nigel
* Ceiling mount pedal box (brakes and cable clutch). Hangs on chassis rail with built in steering column mount. Checker plate of clutch pedal now
found. £40 or £47.50 posted
* Servo and M/C, unsure of origin but suspect Escort mk1/2. There is a bracket to mount the servo away from the bulkhead (not shown). Comes with
~0.5m blue low pressure textile covered hose (came from CBS). £20 or £30 posted
* Or the lot for £80 or £95 posted
* X-flow (?) starter motor, unknown condition. Free to collector
* Type 9 speedo cable. Free to collector or £5 posted First Dibs to chris_smith
* Reversing light. Free to collector or £5 posted.
* Engine mounts. For a X-flow (I think). Free to collector or £5 posted.
* Type 9 shifter. Free to collector or £5 posted. First dibs to Gavin174
* Shifter extension. Previous owners attempts at a shifter extension. Needs work but might be of use to someone. If I can find it will come with a
tatty Lotus gear knob. Free to collector or £5 posted. First dibs to Gavin174
SAS Wheel Clamp Used a couple of times when I borrowed a trailer to collect my part-built. £70 from Trident Trailers. £50 or £60
posted
4x Rachet Straps with wheel straps Used once to get my kit back home. 50mm wide, 3.3m long, 300mm wheel strap. £15each from machine mart.
£35 or £45 posted First Dibs to Bob Tatt
[Edited on 23/11/08 by Hugh_]
Ben_Copeland
posted on 23/11/08 at 03:28 PM |
Cycle Wings please
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
gavin174
posted on 23/11/08 at 04:01 PM |
gear lever and the extension please..
will need them posting please
[Edited on 23/11/08 by gavin174]
fazerruss
posted on 23/11/08 at 04:05 PM |
type 9 gear stick/shifter please
"if assholes could fly this place would be an airport"
bob tatt
posted on 23/11/08 at 04:29 PM |
ratchet straps if there not gone let me know how you want paying
rob
Hugh_
posted on 23/11/08 at 04:31 PM |
First dibs on gearlever and extension to gavin174, fazerruss has 2nd dibs
gavin174
posted on 23/11/08 at 04:40 PM |
cheers hugh..
do you have paypal or do you want a cheque
Hugh_
posted on 23/11/08 at 04:45 PM |
Paypal to hugh_gabriel (at) msn.com would be perfect. Let me know your address and I'll get them in the post asap (probably Tuesday).
Hugh
bob tatt
posted on 23/11/08 at 04:46 PM |
money sent let me know it worked ok
rob
gavin174
posted on 23/11/08 at 04:50 PM |
paypal payment made
cheers hugh
Hugh_
posted on 23/11/08 at 04:59 PM |
Payment received from Gavin, I've not received anything from you yet Bob.
Hugh
chris_smith
posted on 23/11/08 at 06:56 PM |
type 9 speedo cable if still available email sent
Hugh_
posted on 23/11/08 at 07:28 PM |
Replied
bob tatt
posted on 23/11/08 at 08:41 PM |
says its waiting to be acted on by you check your email to see if its not worked let me know and i will sort it
rob
sent it to the right address now
[Edited on 23/11/08 by bob tatt]
Hugh_
posted on 23/11/08 at 09:09 PM |
Now received, thanks Bob
Hugh_
posted on 25/11/08 at 06:53 PM |
All bits paid for have been sent, except the rachet straps which will be in tomorrows post.
chris_smith
posted on 25/11/08 at 10:10 PM |
hi hugh sorry for delay only just read your email, i have sent payment to paypal account and sent email
cheers
chris
Hugh_
posted on 29/11/08 at 11:19 AM |
bumpety bump
Hugh_
posted on 30/11/08 at 06:30 PM |
And again for the sunday crowd (it worked last week!)
chris_smith
posted on 30/11/08 at 06:34 PM |
hugh did you manage to send the speedo cable yet as nothing has arrived
cheers
chris
Hugh_
posted on 30/11/08 at 09:26 PM |
It was posted yesterday but was about 2 minutes after the collection time so it might not have gone until today.
Hugh
chris_smith
posted on 30/11/08 at 09:44 PM |
no probs hugh thanks again
