jambojeef
posted on 29/12/08 at 01:39 PM |
FS: 1.8 K Series Engine from MGF
Anyone need one of these?
Its from my girlfriends MGF which took a diversion into the scenery over xmas thanks to an icy corner...
Done 93k miles, recent service with oil, filter plugs etc - receipts to show replacement head gasket and head skim within the last 2 years.
Never used any oil or water - used to pull very well in the MG and gave surprisingly good MPG too.
Its the non-VVC model and is curently in the car so can be heard running.
£300 including ECU, battery, wiring, gearbox, subframe + anything else you want from the shell - i.e radiator, fan etc.
Be quick though, we are moving again and need the space asap!
All offers considered - its gotta go!
Thanks for looking
Geoff
Humbug
posted on 29/12/08 at 02:09 PM |
oooh, I would be tempted as an upgrade if you weren't in the frozen north (whereas I am in the frozen south)
minitici
posted on 29/12/08 at 03:17 PM |
I've posted a link onto the GTM Owners Club Forum.
jambojeef
posted on 29/12/08 at 03:51 PM |
Cheers thankyou!
MikeR
posted on 29/12/08 at 04:49 PM |
Whats the front end like? I'm just thinking you've got pretty much a starter kit to a build your own midi there!
jambojeef
posted on 29/12/08 at 05:14 PM |
Its all there at the moment, all the brakes - running gear etc is all ok - the front and rear are on separate subframes too - could be an easy one if
you didnt want to fabraicate wishbones etc!
wilkingj
posted on 29/12/08 at 05:17 PM |
Coo that would drop strainght into a Metro.... A Wolf in sheeps clothing.
A mate of mine did that... and it went well.
EDIT:
The hard part was the electronics (ECU) and security. He had some chap do that bit for him.
But you could always Megasquirt it.
[Edited on 29/12/2008 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
jambojeef
posted on 29/12/08 at 08:40 PM |
Is the 1.8 the same size physical size as the 1.4 then?
posted on 29/12/08 at 09:11 PM |
Yes, the 1.8 has longer stroke and bigger bore, but shorter rods so external dimensions are the same.
If you were a bit more local I'd have snapped your hand off, planning a K series installation for the Striker.
Hope the girlfriend came out of the experience unscathed
[Edited on 29/12/08 by MikeRJ]
jambojeef
posted on 29/12/08 at 09:40 PM |
She did thanks. Pride damaged but otherwise ok - means she gets to drive our old landy everyday instead though so every cloud......!
