supercat
posted on 16/4/09 at 02:48 PM |
FS: Pinto High Torque Starter
Pinto High Torque Starter for sale, starts high compression engines with less current draw. Removed from my Pinto race engine now I've swapped
to Zetec. Works perfectly.
From the Cambridge Motorsports website - "This high torque, reduction geared starter replaces the original pre-engaged starter fitted to Ford
Pinto engines. This starter motor will start all engines hot or cold regardless of compression. It is suitable for use with 132 /135 tooth ring gears.
It uses a 10 tooth, 25.4mm diameter pinion gear."
http://www.cambridgemotorsport.com/Ford-Pinto-Starter-Motor
Costs £149 ex VAT new, selling for £85 with £10 P&P or collection from Hatfield.
James
kipper
posted on 16/4/09 at 03:44 PM |
Starter
Damit I have just bought one but what a difference it has made. It has made my crossflow a first time starter now .
Well worth the money.
Good luck with the sale.
Regards Kipper.............aka Denis.
Where did that go?
supercat
posted on 25/4/09 at 02:44 PM |
Now on eBay
ebay link
