flak monkey
posted on 19/4/09 at 02:33 PM |
Garage clearout
Been having a sort out in the garage and came across a few bits which may be useful to someone.
Where I havent put a price make me an offer, remember to include P&P
Image deleted by owner
A selection of trim bits and pieces. The large battery terminal covers work well to cover the top balljoint at the front. The gland seals are good for
covering track rod extensions. Small red batt cover sold
Pinto auxiliary belt, brand new.
Pinto cam pulley (also have a bolt and key in one of the other pics to suit), clean and ready to fit, complete with back plate.
Type 9 gear lever, slightly shortened otherwise standard from what I can see.
Fiesta engine mounts, commonly used in locosts. Were a tad soft for my pinto, but would be ok for a zetec or something lighter.
Bosch pinto dizzy cap. Used but in good condition.
Pinto 88deg thermostat. Fitted to mine for about 500miles.
Complete set of pinto HT leads inc coil lead. 8mm high performance silicone.
Set of almost new APR6FS pinto spark plugs. Been run for a few mins to try and diagnose my ignition probs.
Type 9 gearbox layshafts. 1 brand new, other 2 used but no measurable wear. I also have a complete gear set for a type 9 which is in good
condition.
Pinto oil pressure switch
Pinto water temp sender (std)
Pinto valve springs. Standard, low mileage.
Belkin Serial 9 pin male to female extension type cable.
Dash 3 braided hose fittings. All M10x1 thread. 2 male convex seat and 2 female concave seat. SVA OK.
Pinto fuel pump drive pin
Accelerator cable adaptor for twin cable applications. Block fits on top of accelerator pedal to convert to twin cables. Sold
Bolt and key for cam pulley.
Set of new lay gear bearings for type 9 box.
Seal for speedo output on T9.
Pair of cortina M16 calipers. Seen better days to be honest and one is seized. Could be useful to rebuild or as an exchange set for someone to avoid
the surcharge?
Various type 9 parts. Let me know what you need and I'll see if I have it. Big stuff is collection only, but small bits I can post.
3?! sierra rear hubs for drum brakes.
Like I said, make us an offer if there is anything you want/need.
Got a load more SVA stuff to put up, but Matts got it all at the moment!
[Edited on 19/4/09 by flak monkey]
Sera
http://www.motosera.com
aerosam
posted on 19/4/09 at 03:52 PM |
ahh, the good old 9-pin serial cable, as fitted to many Sierra's!
Had enough of this dictatorship known as LCB. Gone elsewhere, not coming back. Kiss my ass ChrisW.
flak monkey
posted on 19/4/09 at 03:57 PM |
Lol, maybe not, but useful for megasquirt maybe?
Sera
arrow-engineering
posted on 19/4/09 at 04:40 PM |
earoquip
how much for the braided hose fittings, all 4 please
flak monkey
posted on 19/4/09 at 04:58 PM |
You have U2U
Sera
matt.c
posted on 19/4/09 at 07:51 PM |
Urm yeh! You can have all the SVA rubbish back now i have fitted the new stuff.
flak monkey
posted on 21/4/09 at 01:02 PM |
Also got a set of SVA ok indicators on black nylon extensions (£15 for the pair please), a sierra steering wheel (free) and a few other SVA bits and
bobs if anyone needs anything.
Give me a shout.
Can take small stuff to Stoneleigh (there all weekend!), but bear in mind I will be in the GTS so space at a premium!
Sera
Daddylonglegs
posted on 21/4/09 at 01:11 PM |
u2u sent
