Author: Subject: Dyna RPM Limiter and flat shifter
flak monkey
posted on 28/4/09 at 06:05 PM Reply With Quote
My RPM limiter is now surplus to requirements.
Its a Dyna DRL300 limiter, capable of limiting up to 4 coils (so suitable for COP applications) and for both wasted spark and normal.
Its also got an input which when you apply 12v to it it will cut the spark momentarily, this means you can use it as a flat shifter too.
The best thing about it is that you dont need to rev the nuts out of your engine to set the limiter, you just adjust the pot on the end to change the limit.
Will limit up to 18,000rpm so suitable for bikes too.
Installation instructions are here:
http://www.dynaonline.com/skins/downloads/instruct/DRL300.pdf
I think its one of the best limiters available and with the inclusion of a flat shift function its brilliant.
More info here:
http://www.dynoman.net/ignition/dynaRev.html
£50 posted or can bring to stoneleigh
[Edited on 28/4/09 by flak monkey]
Sera
http://www.motosera.com
flak monkey
posted on 30/4/09 at 07:08 AM Reply With Quote
£40
Can bring to Stoneleigh if required.
Sera
