flak monkey
| posted on 5/5/09 at 06:52 PM |
Clearout - All sorts of stuff
Time for a clearout as I have so much stiff laying around it's unreal.
Prices include P&P, paypal is fine.
Dyna DRL300 limiter, capable of limiting up to 4 coils (so suitable for COP applications) and for both wasted spark and normal.
Its also got an input which when you apply 12v to it it will cut the spark momentarily, this means you can use it as a flat shifter too.
The best thing about it is that you dont need to rev the nuts out of your engine to set the limiter, you just adjust the pot on the end to change the
limit.
Will limit up to 18,000rpm so suitable for bikes too.
Installation instructions are here:
http://www.dynaonline.com/skins/downloads/instruct/DRL300.pdf
I think its one of the best limiters available and with the inclusion of a flat shift function its brilliant.
More info here:
http://www.dynoman.net/ignition/dynaRev.html
£SOLD
9 pin serial cable, male to female, 2m long. Belkin, unused. Will work with megasquirt. £5
Web Easy 7 Pro website creator. Brand new on CD. Un-needed as I use different software. Legit copy with activation key etc. £15
Clicky
Pair of rubber engine mounts. Ford Fiesta - suit most seven type cars £8
Pinto cam pulley, cleaned and painted, complete with back plate. £8
Set pinto spark plugs. NGK AP6FS run for a few mins then removed. £8
Set of std pinto valve springs £8
Brand new type 9 layshaft and bearings £15
New speedo output shaft seal for type 9 £5
Pair of cortina M16 calipers. I know one is siezed but will be ideal for exchange to avoid a surcharge. £FREE to collect only.
Various Type9 gearbox parts. Let me know if you need anything.
Pair of Sierra rear hubs for drum brakes. £10 to collect only
Pair of SVA ok indicators on turned black plastic extensions. My car passed with them fitted, as did Matts (see pic). £15
Sierra steering wheel - used for SVA. Free to collect or £15
4AGE MR2 electronic ignition coil and amplifier £20
PS3 GAMES
Devil May Cry 4 - special edition in metal case, collector cards ect. £18
Skate - brill skate boarding game £15 inc
Motorstorm - pre platinum edition £10 inc
PC GAMES
Far Cry 2 £20
Grand Theft Auto 4 £20
GTR - best racing sim ever £SOLD pending payment
GTR 2 - followed by this one! £SOLD pending payment
Logitech Formula Force EX - force feedback steering wheel and pedals for PC excellent when used with GTR/GTL. This is the one Cli cky Very little use,
still in oiginal box. £SOLD pending payment
Also have some stuff on ebay at the moment
http://shop.ebay.co.uk/merchant/666devious666
Duratec alternator is small (70amp) and fitted with poly vee pulley, needs to be mounted on drivers side, which is impractical in my GTS. Might be
useful to someone?
Open to offers on all. It's all got to go...
[Edited on 10/5/09 by flak monkey]
Sera
http://www.motosera.com
skodaman
| posted on 5/5/09 at 07:05 PM |
U have u2u Flak
Skodaman
zilspeed
| posted on 5/5/09 at 07:19 PM |
u2U re rev limiter.
flak monkey
| posted on 5/5/09 at 07:29 PM |
quote: Originally posted by skodaman
U have u2u Flak
ummm, no i dont not from you anyway!
Sera
matt.c
| posted on 5/5/09 at 07:52 PM |
Feck i thought you were trying to sell my car for a min!!!!!!!
flak monkey
| posted on 5/5/09 at 08:00 PM |
Can be arranged
Sera
flak monkey
| posted on 7/5/09 at 09:29 AM |
BTTT
Sera
flak monkey
| posted on 10/5/09 at 05:48 PM |
Bump
Sera
