jolson
| posted on 3/6/09 at 08:21 PM |
more stuff to travel to Cornwall for
I'm clearing the last few bits out of the garage. I haven't put it all together yet, but here's a general list of what's
going:
- MT75 gearbox
- 2 @ 7.5" Sierra diffs (one open - the area around the seals is a little wet, one LSD in good condition, ratio for both is std Sierra - 3.68
sounds familiar, but I'd have to look up the codes again to be certain)
- a propshaft made from splicing a Sierra coupling onto a Ford Transit version with the sliding joint
- a dedion tube with fittings for a Satchell link (Mr. Satchell checked the geometry!) + drawings
- Sierra halfshafts and disc brake rear hubs, and 5 reasonable-ish wheels.
£50 for the LSD and you can have what want of the rest of it (what isn't taken goes to the tip as scrap metal).
I'm still digging out parts, but everything should be there somewhere.
Can't/won't post, it's all too big and awkward (much like myself!), and the postage would be cost more than the bits are worth.
If you want pictures or specs let me know.
John
| posted on 3/6/09 at 09:28 PM |
U2U sent
adrianreeve
| posted on 4/6/09 at 06:58 AM |
U2U sent
mcerd1
| posted on 4/6/09 at 07:39 AM |
diffs will be 3.64
motorcycle_mayhem
| posted on 4/6/09 at 08:16 AM |
While you're picking up LSD bits, probably a great opportunity to pick up your roll bar. CDS, Westfield fitment, weld it on, I do have the
mounting plates (fresh, laser cut) if you want to bolt the hoop on. I've only removed this because I've gone for a cage.
http://img151.imageshack.us/img151/5508/baroffcar.jpg
Just off the A30, North Cornwall. Drop me line if you're interested., £70.
jolson
| posted on 4/6/09 at 01:36 PM |
I've got a couple of people coming to have a look at the bits this weekend, and it's likely they will all go. I will re-post if anything
is left over.
Thanks for the interest
John
Lightning
| posted on 4/6/09 at 03:27 PM |
Jolson,
Just did some repairs at Stithians school, small world
