evo.rocks
| posted on 10/7/09 at 10:39 AM |
FS - ZX12 Exhaust Can
As above, i have the ZX12 can for sale. I am looking for only £25 and i can get this delivered anywhere in the country for about £12. It is a good
exhaust for trackdays etc as it keeps down the noise compared to those race cans. If your interested U2U me
Flamez
| posted on 10/7/09 at 10:42 AM |
What are the dimensions, what pipe does it fit?
my build mac1motorsports
evo.rocks
| posted on 10/7/09 at 10:56 AM |
its designed for a 2" (50mm) pipe. I am not to sure about the dimensions, i would guessdimate at about 400mm in lengh with and OD of 120mm. This
is a pic of how it looks on my MK Indy
dan__wright
| posted on 10/7/09 at 11:01 AM |
first dibs please.
does it have a cat in it?
is the bolt on pipe included?
paypal okay?
evo.rocks
| posted on 10/7/09 at 11:11 AM |
Ok no probs. I couldnt tell you wether it has a cat in, however i can tell you that on the ZX12R spec it says they have cat built in the exhaust
system and it is nowhere to be seen in the pipage. It does get me through my MOT though and it has a nice deep roaring sound.
The link pipe is not included i have used this for my new pipe. Also the bracket is not included as i have also used this for my new can, this is why
i am only selling it for £25
I must say before you purchase it that there are a a few scrathes on the underside of the can which cannot be seen if being put on a kit car, this is
due to put holes ect as it has scraped on the floor and it will only get more when you use it.
It is a titanium can aswell and is in perfect working order.
Paypal is fine, U2U me and we will sort out payment?
dan__wright
| posted on 10/7/09 at 11:16 AM |
okay, no problems about the scratches etc.
do you know wherfe yioiu can get the flanges for the end so i can make a pip up? mount etc is fine as i already have some.
evo.rocks
| posted on 10/7/09 at 11:29 AM |
ime not to sure mate, ime sure that you could fabricate it yourself though, i think this one has. All you need is a small sheet of stainless, cut a
circle out put a 2" hole central in this, the drill the holes for the fixings and bobs you uncle . It would probably cost you a fiver is
that....
dan__wright
| posted on 10/7/09 at 11:36 AM |
okay, if you could confirm the length of it and if possible check if it does have a cat in it (should see a honycomb if you look through it) then ill
deffo have it
evo.rocks
| posted on 10/7/09 at 11:57 AM |
ok just took the exact measurements. it is 495mm in lengh with a OD of 130mm.
Here is a pic of the inside of the can to confirm it has a built it CAT.
evo.rocks
| posted on 10/7/09 at 11:58 AM |
evo.rocks
| posted on 10/7/09 at 01:56 PM |
CAN SOLD ..................
