Author: Subject: Clear out, stuff 4 sale.
big_wasa
posted on 11/10/09 at 01:20 PM Reply With Quote
Ford 1.8cvh fly wheel and full clutch, can be used on a zetec as a light budget set up but will need holes drilling out from 10mm to 11mm and a trigger wheel mounting on the front pulley. Clutch plate is 220mm in size.
May be of use on a Duratec but not yet proven. £30
Ford zetec 2.0 flywheel and 240mm clutch. £10
Mnr steel rack extensions sold
Short rack extensions sold
2.0 silvertop zetec throttle body £20
Cvh sierra front pulley with trigger wheel (heavy for postage ) £6
Cvh sierra cam belt tensioner and bottom pulley £ offers ?
Cvh sierra Inlet manifold and Carb £10
Cvh sierra dash and surround sold
Weber Tps bracket. sold
Cbr900r fireblade carbs in very clean condition with trumpets and mounting rubbers and tps sensor. £55
Rear wings in yellow. They don’t have a flat mounting flange I was told they may be for a Westfield ? Or another car with a rounded rear tub. Never fitted just sat on a tin of beans lol, 12” wide well made but do have marks/ scratches from poor storage. £40
Pics
And testing the water as I fancy going injection and having a play with a supercharger so,
2.0 Zetec spec Weber Dcoe 45 / Dunnell set up.
Zetec spec 152g dcoe 45’s with five progression holes. 60mm Trumpets and k&n style filters.
Twin Webcon under carb linkage with cables and block. Choke cable as well but never fitted.
Manifold and fitting kit ( Shown separate not one fitted to engine )
Dunnell clubman’s ecu with 3d upgrade and new Loom and service.
Webcon pump runs at 2psi especially for Weber carbs.
So that’s Twin 45's on zetec manifold with filters and throttle linkage and cables. Ecu and new loom, Instruction manual, pump and filters.
To give you an idea,
ecu receipt says £666.81
Upgrade receipt says £243.82
Carb receipt says £640.37
Filters £54.50
fuel pump £44
Linkage kit £80
They are not new and have been running my engine for the last six years but never driven as the cars not finished .
Vid
£700 and no that does not include engine just add up what’s there.
Collection welcome but will try and post all but the biggest items by parcel to go or Royal mail for the small bits. As ever first shout to you lot before eBay. If you feel something is the wrong price then discuss it with me I don’t bite.
[Edited on 11/10/09 by big_wasa]
lsdweb
posted on 11/10/09 at 01:29 PM Reply With Quote
First dibs on the Webber TPS bracket p!lease
Wyn
carlknight1982
posted on 11/10/09 at 01:35 PM Reply With Quote
is there any wiring with the dash?
carlknight1982
posted on 11/10/09 at 01:36 PM Reply With Quote
2nd dibs on the tps bracket please
gavin174
posted on 11/10/09 at 05:40 PM Reply With Quote
u2u sent
D Beddows
posted on 12/10/09 at 10:55 AM Reply With Quote
Have you got a picture of the mounting faces of the rear wings?
big_wasa
posted on 12/10/09 at 03:53 PM Reply With Quote
pic 1
big_wasa
pic 2
dave r
posted on 12/10/09 at 04:01 PM Reply With Quote
u2usent
norfolkluego
posted on 14/10/09 at 06:24 PM Reply With Quote
And another U2U
