Lurch88
posted on 19/10/09 at 06:38 PM |
R1 Engine For Sale
For Sale R1 Engine
1999 4XV
13000 Miles
Fitted with Barnett Coil spring conversion
Fitted with Prop adapter instead of Sprocket
Kevlar Clutch Plates (OEM Kept in you prefer)
Oil cooler Bolt drilled for Oil pressure sender (Sender fitted on S/S pipe)
Bolted into MK mounting Cradle Lower engine brackets Kept as well
Reversed Original air box (Fits under MK bonnet Bulge)
The sump has been cracked on a stone but has been professionally repaired
Probably stronger then original (If not as pretty)
Would prefer local pick up but will courier if necessary.
Need it out of my Garage
Located on the Cornwall,Devon boarder
£600
Image deleted by owner
[Edited on 19/10/09 by Lurch88]
twybrow
posted on 19/10/09 at 06:42 PM |
Your location would help for local pick up!
Good price for all that lot.... Best of luck with the sale.
grub
posted on 19/10/09 at 08:24 PM |
i think he is near cornwall and devon at a wild stab in the dark
Hugh_
posted on 19/10/09 at 09:02 PM |
Sounds like a bargain, sorely tempted for my next one...
posted on 19/10/09 at 09:09 PM |
you can just tell he edited that in though!
