Zetec Inlet Manifold and ZX6R Carbs
I've got the above surplus to requirements if anyone is interested.
Home made manifold using Shorttrack manifold plate.
It isn't pretty, and I certainly wouldn't describve it as well welded or finished, but I've tried it and it works perfectly. The plate
is slightly warped from welding it up, but it pulls straight and seals fine when fitted.
I've also got ZX6R carbs with TPS and rubbers to go with it.
The bore of the manifold has been smoothed out with chemical metal, and ideally could do with a bit more work.
The manifold is angled to tilt the crbs up a bit, though not as much as they are on the bike.
This doesn't make any difference to how they work - the carbs on my car are completely horizontal and work perfeclty.
The carbs have standard jets so will need opening up [I opened mine to 1.6mm]
Not sure what it's worth, so open to offers.
Stu
