Radiator - suit midi or wide low fronted car
Morning chaps, b4 i stick it on Ebay thought I'd give you the chance. I bought this brand new intending to use it in the original Furore but used
the bike rads instead, I use a different rad for the production Furore so now surplus to requirements. It's brand new but has a few damaged fins,
nothing that would cause a problem.
[img]
  midi rad
[/img]
Even has a rad fan switch already fitted! measurements are 685mm total width, 310mm total height (across the mounting pegs) mounting pegs are 662mm
centre to centre & height of core is 270mm
Modern, lightweight ali & plastic
£30 inc P & P to any "normal" Uk address
