Rek
posted on 5/3/10 at 01:15 PM |
£105 plus vat for a Lambda Sensor....
and it's only an omega!!! plus they wanted £75 an hour to fit it too.... would be cheaper to hire a solicitor to do it....
posted on 5/3/10 at 02:57 PM |
The Omega probably uses a Titania sensors so they do tend to be a bit more expensive. Was that for a genuine sensor or an aftermarket part?
If you fitted these things regularly you'd probably give a high quote as well to cover the utter b***ard ones that really don't want to be
removed.
[Edited on 5/3/10 by MikeRJ]
posted on 5/3/10 at 04:25 PM |
Some Omega lambda sensors are only availble through the dealer network, the sensor would have to be changed -- usually not easy then the operation
checked on a diagnostic scanner.
goaty
posted on 5/3/10 at 05:21 PM |
suzuki wanted £155 plus vat for the Mrs motor ![](/images//smilies/shocked.gif)
NigeEss
posted on 5/3/10 at 07:15 PM |
Mazda MX5, £170 from my local factors and that was with trade discount ![](/images//smilies/shocked.gif)
matt_gsxr
posted on 5/3/10 at 07:24 PM |
I'd recommend against getting a solicitor to do it. They will do a rubbish job, and will be difficult to claim the money back from!
Matt
posted on 5/3/10 at 08:09 PM |
Zuki's are very very fussy about lambda sensor only the genuine article will do.
AndyGT
posted on 5/3/10 at 09:54 PM |
Matt
Plus usually they don't know the difference between their arse and elbows!!!![](/images//smilies/shocked.gif)
nothing is impossible
everything is possible
