Author: Subject: MKII Escort
Dopdog
posted on 11/4/10 at 01:21 PM Reply With Quote
MKII Escort
Due to change in circumstances regrettably my pride and joy is up for sale.
I converted the car last year to Cosworth power, but have since found out the engine needs to be rebuilt. The car at the moment is complete less engine as I have removed this to rebuild it. The spec of the car is as follows.
Olympic Blue with Black Mexico strips. This Shell is a very solid and needs no work at all as you can see from the pictures.
Cobra Immobiliser
Alloy door cards
Original Mexico Rolltop Recaro seats in very good condition, carpet and rear seat, RS glovebox and dash pod
2 x 3 point Sparco harness
Full bolt in Safety Devices Roll cage with diagonal (no door bars)
Large diff tunnel and engine bay gussets
RS boot Spoiler
GR4 Alloy front spoiler
4 x Cibie Spot lights
6x13 Minilite split rim replicas with 185/60/13 tyres, Rolled arch lips so no rubbing.
Battery in boot
2 ¼ Front adjustable Billys with 2.8 vented discs and callipers
New 300lbs springs
New roller top mounts
2.4 Quick rack
New R.A.C.E WCXM with lower rack mount
New Group 4 Steering Joint
Double width kit
Anti dive kit
New Bias Pedal box
Rear on 2in lowering blocks
3.54 diff
One piece up-rated prop
Recon T5 box
Samco hoses
Group A coil
Bailey Dump Valve
Bailey Oil breather kit
Group A Filter in inner wing
New Radtec Radiator and Intercooler
New 2 ½ in twin box right hand side system
The Engine has had the following work carried out.
Refaced block
Rebore +1mm
New Forged pocketed Wossner Pistons
New big and main bearings (standard)
Crank standard polished and balanced with lightened flywheel
New Uprated Clutch and pressure plate with dowel pins to flywheel
New ARP conrod bolts
New thrust bearing
New modified SFS baffled sump and baffle
Complete Cometic Gasket set
New Head bolts
New followers
New Valve stem oil seals
New T3 Turbo
The head just needs new valve guides fitting and this would give you a new Engine. The engine just needs to be rebuilt and put back in the car, I have all parts to do this and is all clean and painted. I am sure there is more!
This car owes me much more than the asking price so grab yourself a good deal with a nice quick starter for this season. I would like to sell as a complete package but if someone wants just the rolling shell less engine I can do a deal. Just needs a centre consle to cover the split in the carpet for the large tunnel.
£10,999 ono for the complete car but as said am open to offers for the rolling shell less just the engine Rescued attachment DSC02262.JPG
