daniel mason
| posted on 25/4/10 at 08:18 PM |
for sale, westy discs and cosworth calpers
a couple of items of mine are now for sale. first a pair of westfield rear discs,cross drilled, brand new and supplied from westfield,4x108
studs,these are now surplus to requirements.
2x what are believed to be sierra cosworth 2wd rear calipers, also brand new. i bought these by mistake from ebay and the listing stated 2wd sierra
cosworth rear calipers,brand new, and retail at over £200
items are on ebay, user name lfc01234 but u2u with offers if interested!
cheerszIQ!Wk~$(KGrHqYOKj4Et18(h!h1BLqSo)ZPRQ~~_35.jpg)
daniel mason
| posted on 25/4/10 at 08:19 PM |
and again
doddy
| posted on 25/4/10 at 08:20 PM |
heres a link
http://cgi.ebay.co.uk/sierra-cosworth-rear-calipers-also-kit-car_W0QQitemZ260592237891QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3c
ac81fd43
daniel mason
| posted on 25/4/10 at 08:24 PM |
thanks doddy!
mcerd1
| posted on 25/4/10 at 11:56 PM |
btw - there are only 2 kinds of rear caliper for all the sierra's, granada's, scorpio's - ones for vented discs and ones for solid
discs (although the hub's and discs are different)
the 2wd cossies have the solid disc type, same as XR4x4's and other normal sierra's with rear discs
just out of curiosity - what calipers are you using ?
alexg1965
| posted on 26/4/10 at 06:48 AM |
Definitely look like 2WD Cossie rear calipers. Here's a picture of one of mine, painted black of course. And they also use solid discs, as has
already been said.
daniel mason
| posted on 26/4/10 at 04:51 PM |
i think i will use wilwoods if i can strike a deal!
mcerd1
| posted on 26/4/10 at 11:41 PM |
does one of your calipers (can't remember which side) have '0658/4' cast into it ?
daniel mason
| posted on 27/4/10 at 04:51 PM |
^^^ i will check later
daniel mason
| posted on 27/4/10 at 08:39 PM |
mcerd1.. they say 0659/4 not 0658/4
mcerd1
| posted on 27/4/10 at 08:56 PM |
just found my other one - should be one of each of those numbers (ones LH the others RH)
if thats the case then thay are a pair of the same type as I've got from my 2.0 granada
in which case they are the solid disc type and should fit all of these:
sierra cossie 2wd's, XR4i's, XR4x4's, sierra's with ABS, mk3 granada's, scorpio's
(but not sierra/sapire cossie 4x4's, escort cossie's or granad /scorpio 24v cossie's)
[Edited on 27/4/10 by mcerd1]
