flak monkey
| posted on 5/5/10 at 06:14 PM |
Clearout with pics this time
All plus P&P
Coil pack supressor, normally used with megasquirt and zetec coils £5
Image deleted by owner
Bosch recirc valve, std fitment on all turbo VAG cars amongst others. £5
Bosch silicone coil lead £2
High and low pressure fuel filters. £5 and £10 respectively
4 off high quality 316 stainless 45deg bends. 38mm OD. £20 (normally £10 each)
Knock sensor - £5
Set of duratec (EV6) injector connectors. With loads of wire attached £5
Ford fiesta/ka sterring coupling. Fits the escort mk2 rack. Has a hex in the other end, but can be welded.
2 off 3" dia 90deg alloy bends. Ideal for air intake/turbo etc. sold
Wilwood smart pads to fit powerlite calipers. Lightly used, but loads of life left. sold
E marked reflactors. Sticky backed. £2
Air control valve - for idle speed control. Ford 2 pin £5 sold
New ignition coil and balast resistor. £15
CBR600 throttle bodies. 32mm bore, the ones with sliders as well. No injectors £30
[Edited on 6/5/10 by flak monkey]
Sera
http://www.motosera.com
scudderfish
| posted on 5/5/10 at 06:17 PM |
I'll have the idle valve please.
Hugh_
| posted on 5/5/10 at 07:12 PM |
I'll have the pads please.
ashg
| posted on 6/5/10 at 07:58 AM |
2 off 3" dia 90deg alloy bends. Ideal for air intake/turbo etc. £15
i will have the air feed alloy bends
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
flak monkey
| posted on 6/5/10 at 08:22 AM |
Pads, 3" bends and idle valve sold.
Everything else still available.
Sera
rost
| posted on 8/5/10 at 09:48 AM |
u2u'd for recirc valve and steering coupling
Charlie don't surf!
