matt_claydon
posted on 10/5/10 at 06:51 PM |
FS: Prop shaft (shortened) for Type 9 gearbox
Modified by MK to suit a Pinto Indy but likely to suit many other installations.
Overall length - 785 mm
Diff flange to gearbox tail with splines fully inserted - 680 mm
Allowing for appropriate clearance, this is suitable for a gearbox tail - diff separation of about 705-730mm.
£35, collection from Bristol preferred if possible but happy send at cost (Paypal).
MK Prop
[Edited on 10/5/10 by matt_claydon]
handyandy
posted on 10/5/10 at 06:55 PM |
does this fit the sierra diff?
if so , i,ll measure my car in the morning & if it,ll fit may i have first dibs please?
cheers
andy
matt_claydon
posted on 10/5/10 at 07:04 PM |
Yep, Sierra diff (which also means English axle etc I think, but I was using it with Sierra running gear).
handyandy
posted on 10/5/10 at 07:26 PM |
cheers Matt,
will get back to you in the morning when i,ve checked my car ( car not being built at home).
thanks
andy
stevegough
posted on 10/5/10 at 07:29 PM |
Cautionary note...
Sorry to butt in, guys but I was sold a similar one by a guy on here who said he 'thought' it was 'english axle and he
'thought' it would fit a sierra diff.
We exchanged measurements, and I bought it.
It didn't fit the diff - it was about 10mm smaller. I still have it - will be going in my 'post build garage clearout' eventually!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
matt_claydon
posted on 10/5/10 at 08:49 PM |
Fair enough, but as I had it fitted to Sierra running gear I think it's safe to say it fits! Forget the comment about English axle...
handyandy
posted on 11/5/10 at 11:36 AM |
Hi Matt,
as promised, i,ve measured my prop distance but sadly your prop won,t fit my car ,
the distance between the gearbox oil seal to my rear diff flange is only 630mm.
thanks anyway.
cheers
andy
