NS Dev
| posted on 22/5/10 at 09:39 PM |
Hydrovane 43 compressor
Here's my other compressor for sale, which will be going on ebay pretty soon (as I doubt it will suit many on here!)
Its a 10hp, 3 phase, hydrovane machine on a 200 litre tank.
it has recorded around 7500 hours which as you will know if you have looked at these, is absolutely no hours at all!
It supplies 43 cfm, enough to run a small pot blaster (or a big blast cabinet), as well as keep a workshop full of air tools supplied with no problems
at all. When I mention the blasters I'm not talking the diy chinese rubbish, I do mean a lot of air!!
You can open a 1/4" bsp 1/4 turn valve full open on the tank and it will just about keep up without losing pressure.
It is incredibly quiet when its running, much quieter than most piston compressors.
Only fault is a very slight oil weep, which appeared to come from the oil cooler, but now seems to have disappeared again. I've never had to top
the oil up in 500 hours use so it can't use much.
Its done around 600 hours since its last oil change service which I did when I bought it, with the proper 2000 hour oil
As I said, prob not much use to many on here, but I'm after £500 for it
ashg
| posted on 23/5/10 at 08:00 AM |
u2u sent
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
big_wasa
| posted on 23/5/10 at 08:28 AM |
well cheap for that much air. I want 3 phase
NS Dev
| posted on 27/5/10 at 03:11 PM |
now sold for £650
