bigsteve
posted on 23/5/10 at 05:01 PM |
fireblade digital dash
i'm after a digital dash for my 919 blade engine. i really like the koso DB02 but from what i've read on here, people have trouble with
the rpm signal with koso units ?? i've also thought about the acewell 3250
anyone have any recomendations??
[Edited on 23/5/10 by bigsteve]
iank
posted on 23/5/10 at 05:28 PM |
Only problem with acewell 3250 is it's a bit plain.
russbost is the best way to get acewell stuff as he does a discount for locostbuilders, he has a few new units available.
http://www.locostbuilders.co.uk/viewthread.php?tid=135870
http://www.locostbuilders.co.uk/viewthread.php?tid=136273
Anonymous
bigsteve
posted on 23/5/10 at 05:36 PM |
i know what you mean about the acewell being a bit dull and i got a good price off russ for one. its only going to be used for track use so
i'm not too bothered what it looks like as long as it does the job. if the koso one will work reliably i'll go for one them
mad-butcher
posted on 26/5/10 at 08:27 PM |
acewell does the job for me, I'm driving the thing not entering a beauty contest.
tony
bigsteve
posted on 26/5/10 at 08:38 PM |
tony
thanks for that. how did you do the speedo feed??
bigsteve
posted on 28/5/10 at 06:37 AM |
Sorry meant the rpm signal
Scott W
posted on 28/5/10 at 07:51 AM |
We're using an ETB dash with our 919 engine, but the principle should be the same. We've simply taken our RPM feed from the little black
control box (forget the exact name right now!) as there is a dedicated wire for RPM.
I can tell you more when I get home tonight and have the wiring diagram/car in front of me if you want.
Kriss
posted on 28/5/10 at 12:13 PM |
I have a koso and its great. RMP signal was poor as it was wrapped around a coil pack but now its simply tapped into the injector wire I think.
Anyways, its a noce clear signal. or use the ECU feed if its not been chopped off
bigsteve
posted on 28/5/10 at 12:16 PM |
I've heard about some dash's that are a nightmare getting the rpm set up right so any help/ advice would be greatly appreciated. I'd
like the etb dash but its abit too pricey for me
bigsteve
posted on 28/5/10 at 07:13 PM |
which one have you got? i take it its on a blade engine?
cheers
steve
franky
posted on 30/5/10 at 07:11 AM |
Slightly OT but i've got a new stack 80mm all in one dash for sale, obviously the quality is fantastic![](/images//smilies/bigsmile.gif)
bigsteve
posted on 30/5/10 at 02:04 PM |
what model is it, do you have any pics and how much are you after for it?
franky
posted on 30/5/10 at 08:08 PM |
if you u2u me with your email i'll send you details.![](/images//smilies/bigsmile.gif)
