RonaldK
posted on 3/7/10 at 04:25 PM |
R1 engined locost
hi all,
just purchased a super sever with R1 2001 R1 engine. Car is drivable and quite fast but it requires some mods and I need some advice on where to get
the stuff needed.
- Exhaust muffler is badly welded, might want to replace the complete exhaust + manifold. can this be ordered online somewhere and is it a simple bolt
on job ?
- R1 dashboard, the neelde goes to 7, then back to 2, to zero. I assume these are error codes, can someone point me in the right direction
- R1 engine, it uses the stock airfilter atm, would like to replace this with something smaller, can this be ordered online and do the carburators
need rejetting when the filter is replaced ?
Apologies for al the questions, hope you can help.....
thanks,
big_l
posted on 3/7/10 at 08:01 PM |
Carbs will need altering if you fit a filter mate I have done this to mine so I can tell you how !!
Mk do a good manifold or gbs who made mine mnr can also do awsome silences !!!
Check out my blog mnrvortxhayabusa@blogspot.com
multanen
posted on 4/7/10 at 03:21 PM |
7k RPM code indicates missing or broken EXUP.
There should be be actual EXUP-servo in the car or "EXUP replacement module". Otherwise engine won't work well.
RonaldK
posted on 4/7/10 at 05:46 PM |
I'll post some pictures of the engine bay. think the servo is there but will check.
big_I, ill send u a pm for advise.
thx sofar.
