<<  1    2  >>
Author: Subject: Could anyone make me a air duct?
Yazza54
posted on 12/3/11 at 01:18 PM Reply With Quote
Helllooooooo
The air duct I currently have on my fury exits down instead of straight out which means I have a long winding length of duct to my px600 airbox...
If I could get a duct with straight exit into te box I think itd work better and at least look neater. I can't find one of the dimensions I need though to fit under the bonnet bulge..so was wondering if anyone on here could make one? Preferably carbon unless it's going to cost a fortune then ally would be fine.
I'm unhappy cos I eat and I eat cos I'm unhappy
welderman
posted on 12/3/11 at 01:36 PM Reply With Quote
box
Forum Code: airbox
airbox
Thank's, Joe
I don't stalk people
welderman
posted on 12/3/11 at 01:37 PM Reply With Quote
Not sure it would fit as your water header is in a different spot
Thank's, Joe
Yazza54
posted on 12/3/11 at 01:46 PM Reply With Quote
The airbox setup all works fine I just want a duct the size as the one i already have but with back exit to go straight to the airbox. Can't find one as it's not a STD size, it's a Ferrari 360 challenge brake duct I bought which just happened to fit.
I know the ram air effect isnt much on a car but you can't be getting any with an open filter just attached to an airbox?
austin man
posted on 12/3/11 at 02:53 PM Reply With Quote
need fresh air coming in just for the cooling factor, neve fancied drawin air in from down low as I ave come across a coulpe of cars that thought they where wet and dry vacs when the hit a deep puddle. Both engines totally fubbared due to bent rods
Yazza54
posted on 12/3/11 at 03:01 PM Reply With Quote
It is high up but the exit is at 90 degrees down hence the duct going from the box, under the cross member and up to the duct outlet
tul214
posted on 12/3/11 at 03:04 PM Reply With Quote
You need something like Yella Terra Over The Radiator Cold Air Intake Commodore on eBay (end time 08-Apr-11 11:30:56 BST)
[Edited on 12/3/11 by tul214]
1.6 Raw Super6 sold
Yazza54
posted on 12/3/11 at 03:07 PM Reply With Quote
Well that's what I already have but the exit is down. It's the black thing on top of the rad. It works fine I just want a straighter and shorter duct
Yazza54
posted on 12/3/11 at 03:10 PM Reply With Quote
Maybe I've not explained myself very well. I just need this but In my own dimensions http://www.demon-tweeks.co.uk/Performance/Brakes/Brake_Ducts_Ducting/Revotec_Rectangular_Intake_Duct/864/0/40427
LBMEFM
posted on 12/3/11 at 04:12 PM Reply With Quote
Whoooooooooooooooo Have you seen the price
welderman
posted on 12/3/11 at 05:05 PM Reply With Quote
Ah. Think I could knock something up.
Thank's, Joe
40inches
posted on 12/3/11 at 05:58 PM Reply With Quote
What are your dimensions?
Yazza54
posted on 12/3/11 at 06:06 PM Reply With Quote
200 x 50 rectangular inlet tapering to 75 outlet about 200 long in total
There's ducts that are close but it needs to be those dims to fit snugly under the bonnet bulge on top of the rad. Most of the ones I've seen are 51mm outlets too which is too small ad I don't want to be faffing with adapters.
P.s thanks welderman I've relplied to the yooo2yoo!
indykid
posted on 12/3/11 at 06:30 PM Reply With Quote
Glad you got there in the end
Since that one suits your needs, couldn't you cut the back of the duct off, then bend the wire in the hose into a rectangular shape to match?
It wouldn't need to be perfect and with some tidy duct tape, would look perfectly respectable.
adithorp
posted on 12/3/11 at 07:11 PM Reply With Quote
Thats what I was about to write.
http://jpsc.org.uk/forum/
Yazza54
posted on 12/3/11 at 07:18 PM Reply With Quote
Hmm I want it to look like it was made to do the job
indykid
posted on 12/3/11 at 07:25 PM Reply With Quote
That's down to your fabrication skills I guess. It shouldn't be hard to make a good job of it though
welderman
posted on 14/3/11 at 03:40 PM Reply With Quote
I know its paper but this is what your after i think, with a 75mm bit of tube on the end.
[/img]
Thank's, Joe
Yazza54
posted on 15/3/11 at 04:50 PM Reply With Quote
Yep! How long is that or is it just as an example?
Btw thanks for the u2u totally missed the post
welderman
posted on 15/3/11 at 06:45 PM Reply With Quote
Sample but it's approx 250mm long
Thank's, Joe
Yazza54
posted on 15/3/11 at 07:18 PM Reply With Quote
Would have to be 200mm long to have enough room to fit the pipe but apart from that it'll work. So 75mm pipe, duct 200 long with 200x50 opening. Sound doable? Thanks for this!
welderman
posted on 15/3/11 at 08:28 PM Reply With Quote
Yep
Thank's, Joe
:{THC}:YosamiteSam
posted on 16/3/11 at 11:57 AM Reply With Quote
you could join the 2 together with either heatshrink [if you can find some big enuff] or thin wall rubber pipe thats very flexible - held in place with tie wraps
welderman
posted on 16/3/11 at 01:29 PM Reply With Quote
duct 200mm long
[img]
[/img]
Thank's, Joe
welderman
posted on 16/3/11 at 01:30 PM Reply With Quote
duct 150mm long
[img]
[/img]
Thank's, Joe
<<  1    2  >>
