brookie
posted on 12/11/11 at 07:39 PM |
oil pressure gauge
as above wanting to fit a oil pressure gauge to my blade engine, can i just fit any i now i got to modify it it fit ,just need to now if i need a
special gauge to fit the bike engine
Proby
posted on 12/11/11 at 08:59 PM |
Any oil pressure gauge will do.
mark chandler
posted on 12/11/11 at 09:38 PM |
If you get an electric one then you need to run the sender off a bit of hose, the engine vibrations will kill it otherwise.
The standard light sender sits in a big bung, you can undo this and tap to whatever your fitting is
tony.g
posted on 12/11/11 at 09:50 PM |
I got this reply when I asked about the thread size on a 919 Blade.
The thread is M10 x 1.5 but it might be easier to remove the boss that it screws into and retap it 1/8 npt as most of the aftermarket senders use
this. The boss can be removed from the main oil gallery using a 17mm socket but it is real tight usually. Be creful when refitting the boss as it is
M2o fine and easily cross theaded
Tony
daniel mason
posted on 12/11/11 at 10:24 PM |
In would go with a stack mechanical one. Not too expensive and good quality. I have one on my s2000 engined mnr
bigfoot4616
posted on 12/11/11 at 10:55 PM |
Tony
i was supplied flexi hose and adapter by ETB to replace the standard pressure light switch. spoke to them the other day to find out thread it would of
been and he was sure it was 1/8 BSP
brookie
posted on 13/11/11 at 01:29 PM |
well i spoke to andy at ab performance and he said if i send him my new sender when i get o ne will make me the full unit for me so i will do that
tony.g
posted on 13/11/11 at 07:22 PM |
The answer above came from Andy.
Good luck.
I'll be interested how you get on as i want to put one in my car.
