fullpint
posted on 10/3/12 at 09:31 AM |
Blade 919 airbox..
I'm still on my mission of getting below that 100db and it's been said a few times now that I need a standard air-box.. So who's got
every thing I need? I presume I wont have to change any of the current settings? And hopefully it will fit under the bonnet with out cutting a hole in
it.
U2U me if you can help along with the damage in cash
[Edited on 10/3/12 by fullpint]
I've over 28 years in dealing with magnesium wheels. Refurbishment and can powder coat most metal parts. Visit my web site if you wish..
www.tpcs-magnesium-refurbs.co.uk
wylliezx9r
posted on 10/3/12 at 09:57 AM |
Very much doubt it will fit under the bonnet, had to cut a huge hole in mine. This can sometimes be hidden by adding a big scoop.
George Best
Dangle_kt
posted on 10/3/12 at 10:45 AM |
You can fit the airbox backwards so it has less height.
ReMan
posted on 10/3/12 at 11:05 AM |
Assuming its all standard MK engine mounts/engine height then it WON'T fit under a flat bonnet, even with it turned round, you will need the MK
bonnet with the bulge
www.plusnine.co.uk
fullpint
posted on 10/3/12 at 11:10 AM |
Not cheap getting to that 99db mark!!! Already building up a selection of end-cans.. Now an air box followed by a bonnet.. Will it be worth in the
end for that odd track day or should I just keep it as it is and buy another toy for the collection
mark chandler
posted on 10/3/12 at 01:12 PM |
As your noise is measured at the side the tester will pick up engine and induction noise, you need to route the exhaust out the rear then they will
not pick up this.
Mine failed unless I stood next to the car which pulled it down a couple of DB's as my body blocked the noise a little.
You could also cheat and lay a fireproof lead lined blanket over the engine/induction tract for the noise test, then remove before you venture out.
It is worth it, track days rock try going to a couple of 105db days.
tony.g
posted on 10/3/12 at 02:54 PM |
not pick up this.
I love track days too.
I even had to cut a hole in my bonnet scoop to get the airbox in.
Sorry to hijack this thread.
Mark, where did you get the pipe bent to go to the rear of your car?
