Author: Subject: Bright 6 warning light module (2nd Hand) £16
Andybarbet
posted on 12/3/12 at 09:10 PM Reply With Quote
I picked this up a while ago - it had been previously fitted to a car.
Recently I bought an Acewell digi dash off a fellow locostbuilder & it came with the warning light surround so I dont need the bright 6 anymore, I was going to keep this just incase but am trying to get some funds together to buy a polo radiator so it seems silly to keep hold of it.
I have removed the short stubs of wire that were on it & rewired with about 12" of new wire on each terminal. These were then heatshrunk at the circuit board end, covered in some black silicone for some support, then the circuit board was re-coated in conformal coating to keep the damp out. I have labelled all of the new wires & there is also a printed out instruction sheet with the original wire colours & the new wire colours just incase.
(Im an electronic/electrical service engineer by trade so its not been bodged)
It might just need a bit of double sided sticky tape on the front plastic light cover bit that has the symbols on as its not very sticky now.
They are £30+ new so im looking for £16 including delivery but might not be able to get to the post office until thursday lunchtime.
Bright 6
Bright 6
bright 6 a
bright 6 a
bright 6 b
bright 6 b
Instructions
Instructions
dlatch
posted on 12/3/12 at 09:24 PM Reply With Quote
odd question but how big is your nose cone andy?
i have a brand new polo rad bought in error its the slightly wider version 430mm and almost fits inside my GTS nosecone
but it may suit you, also i see your in herts same as me
if you want it you can have for free, i need it out the way ideally.
Andybarbet
posted on 12/3/12 at 09:32 PM Reply With Quote
Thanks for the generous offer, im not too sure how big the nosecone is, its in my rented garage half a mile away.
I know the Luego nosecone is taller than most by a couple of inches but i think it is normal width, I will pop over my other garage tomorrow evening with a tape measure & let you know.
Im in the Stevenage area so not too far.
Thanks again - Andy
dlatch
posted on 12/3/12 at 09:43 PM Reply With Quote
no problem andy
it really is a close fit in my nose cone but may just fit yours i work in watford btw in case you have relatives there i could drop the rad off
i will double check and measure it tomorrow as i will be down my garage anyway
rachaeljf
posted on 13/3/12 at 01:13 AM Reply With Quote
Andy, U2U sent re Bright 6.
Cheers Rachael
Andybarbet
posted on 13/3/12 at 06:39 PM Reply With Quote
Bright 6 is sold - Thanks
medic_dan
posted on 14/3/12 at 07:13 AM Reply With Quote
2nd Dibs if the sale on the bright 6 falls through please.
Dan
[Edited on 14/3/12 by medic_dan]
