Author: Subject: Garage Clear Out
davidimurray
posted on 30/10/12 at 09:09 PM Reply With Quote
Garage Clear Out
As we're moving house I'm clearing out a few spares and raising a few quid to pay for the transport of my car. Any queries or question don't hesitate to email or PM me.
Seat Runners £10 + P&P
I believe these came from the back seats of a Renault of some form. I've used one set for my own car and these are spare. Only 25mm high. There is some light surface rust on the outside but run smoothly and includes the cross bar
Expansion Tank SOLD
Bought this from a member on locost builders brand new, fitted it to my car and ran it a few times then decided a would prefer a see through tank so I can see the water level easily (I drive a K series engine tin top so am slightly paranoid about water!!) Has a 12mm right angle fitting on the bottom, 10mm fitting on the front and an overflow port at the rad cap. Approx dimensions 220mm across flanges,120mm high and 115mm deep. Is a bit grubby at the moment but will clean up nicely -
Short Sierra Steering Cowl SOLD
Sierra Brake Balance Reducer £5 + P&P
Sierra Fuel Pump including plunger + spacer £5 + P&P
Ignition Leads £5 + P&P
Brand new Motaquip leads froma Ford KA. Not marked as RFI Surpressed so I swopped them for a set that was. Ideal for and Ford EDIS coilpack setup
Haynes Roadster Wishbone Jig £20 + P&P
This is an Armoto machined wishbone jig. As can be seen, it was used to make my own wishbones for my Haynes roadster so has a few burn marks on it. I have relieved the jig slightly to allow me to use 20mm tubing instead of 19mm - this can be seen by the chamfered edges. Few pics of the jigs in use in Gallery 3 of my pics in my signature.
Dave
[Edited on 30/10/12 by davidimurray]
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
daniel mason
posted on 30/10/12 at 09:17 PM Reply With Quote
what is the pressure rating on cap? if reasonably high and it will clean up ill take it please! cheers
Jenko
posted on 30/10/12 at 09:18 PM Reply With Quote
U2u sent re the expansion tank...
MY BLOG - http://westfieldv8.blogspot.co.uk/
davidimurray
posted on 30/10/12 at 09:27 PM Reply With Quote
Expansion tank sold
gavin174
posted on 30/10/12 at 09:36 PM Reply With Quote
steering cowl please
let me know how you would like payment
[Edited on 30/10/12 by gavin174]
daniel mason
posted on 30/10/12 at 09:51 PM Reply With Quote
whos got the tank?
davidimurray
posted on 30/10/12 at 09:53 PM Reply With Quote
Steering Cowl sold
