Author: Subject: Carbon dash F/S - guaging interest
Charlie_Zetec
posted on 22/11/12 at 02:53 PM Reply With Quote
Afternoon all,
I've got my current carbon dash on the GTS that I'm not happy with, and I want to change the layout. As such, I've found a local manufacturer to me in Essex who is going to manufacture me a new carbon dash. I'm having it modified so that there will no longer be the 'dip' in the middle, but it will still have the curvature on each side, as per the diagram;
Dash dimensions
Dash dimensions
The red lines show where the bottom of the new dash will be; essentially a straight bottom edge.
As I'm going to have to pay this guy to mod my old dash, create a mould to manufacture the new one, and produce me a shiney new carbon fibre panel, did anyone else want to take advantage of this and get him to make some more whilst he's at it?
The dash is for my GTS W7DE, based upon the McSorely +442 chassis, but I'm sure it could be cut down to fit other scuttles. Measurements are as follows;
1100mm at widest point - outside bottom corners (A)
280mm at the tallest point - bottom corner to top of dash, perpendicular (B)
200mm high along the centre of the dash (C)
There will be a 10-12mm folded edge along all the sides as well.
I think they're going to work out at £90 each plus P&P.
Thoughts? And sorry if I'm not supposed to post this; I'm not a registered trader, but am not doing this to make money, just an open invite to others who may want a new carbon dash!
