Author: Subject: My Stoneleigh bits for sale...
yellowcab
posted on 30/4/13 at 05:55 PM Reply With Quote
These are things that I can bring to Stoneleigh should anyone want them:
Racetech Mechanical Oil Pressure & Water Temperature gauge, 52mm - £40
http://www.demon-tweeks.co.uk/motorsport/gauges-auxiliary/racetech-oil-pressure-water-temperature-dual-gauge
VDO Vision Fuel Level gauge - £20
http://www.demon-tweeks.co.uk/motorsport/gauges-auxiliary/vdo-vision-fuel-level-gauge
VDO Vision Water Temp gauge (elec) - £20
http://www.demon-tweeks.co.uk/motorsport/gauges-auxiliary/vdo-vision-water-temperature-gauge-electrical
Westfield tacho - £30
MOMO Millenium Evo Steering wheel, 320mm, as photographed, push button horn - Demon Tweeks RRP: £211... £45
Westfield Megabusa Hayabusa drysump pan, slightly scraped but still solid - £20
Westfield Megabusa Hayabusa drysump pan, as new condition with pipes as pictured - £40
Gear indicator brand new, never used, with reed switches, sensors & magnets (blue display) - £10
Drilled & grooved Sierra disks & calipers, good condition, not very old at all £65
Standard set of rear wishbones from an original MK Indy (2x upper wishbones / 2x lower wishbones) - £60
[Edited on 30/4/13 by yellowcab]
SALAD
posted on 30/4/13 at 06:10 PM Reply With Quote
What size is the gear indicator and what gearboxes can it be used with?
yellowcab
posted on 30/4/13 at 06:11 PM Reply With Quote
Gear indicator is 45mm and can be used with BEC/ sequential boxes
SALAD
posted on 30/4/13 at 06:15 PM Reply With Quote
I knew you were going to say BEC but thought I'd ask!
Thank you for the reply but I can't invest, "I'm out".
yellowcab
posted on 30/4/13 at 09:59 PM Reply With Quote
MOMO steering wheel sold to Karl H
yellowcab
posted on 2/5/13 at 02:42 PM Reply With Quote
Back up :-)
yellowcab
posted on 3/5/13 at 09:09 AM Reply With Quote
Happy to accept offers on any of the above if collected from Stoneleigh
