Escort bits for locost with pics
![](/galpreviews/SDC18596.JPG) ![hand brake lever](/gallery/SDC18596.JPG) hand brake lever
hand brake lever £10
[pg]98879[/pg
x flow box clutch operating arm £10
![](/galpreviews/SDC18598.JPG) ![x flow alternator](/gallery/SDC18598.JPG) x flow alternator
Lucas alternator with plug £20
![](/galpreviews/SDC18609.JPG) ![remnants sierra pedal box](/gallery/SDC18609.JPG) remnants sierra pedal box
remnants of sierra pedal box no clutch pedal, there is another
bit not shown in pic as well as a spring , might be of use to some one £4
![](/galpreviews/SDC18614.JPG) ![escort cowl and switches](/gallery/SDC18614.JPG) escort cowl and switches
column switch set and cowl £30
miscellaneous switches pair£7
![](/galpreviews/SDC18618.JPG) ![ger lever , clutch gaiter rod](/gallery/SDC18618.JPG) ger lever , clutch gaiter rod
gear lever
£10
Clutch lever gaiter £5
maxi ball joint and rod end £5
![](/galpreviews/SDC18617.JPG) ![carb linkages](/gallery/SDC18617.JPG) carb linkages
carb linkages pair £5
![](/galpreviews/SDC18600.JPG) ![crank/ fan pulleys](/gallery/SDC18600.JPG) crank/ fan pulleys
Std Crank pulley x flow £10
Fan pulley £8
thermostat housings £5 each
![](/galpreviews/SDC18619.JPG) ![Exhaust silencers](/gallery/SDC18619.JPG) Exhaust silencers
escort boxes std system £20 each
throttle cables and miscellaneous clutch cable
![](/galpreviews/SDC18597.JPG) ![2 hole inertia starter motor](/gallery/SDC18597.JPG) 2 hole inertia starter motor
2 hole inertia starter motor £15
![](/galpreviews/SDC18595.JPG) ![3 hole inertia starter motors](/gallery/SDC18595.JPG) 3 hole inertia starter motors
3 hole inertia starter motors £15 each 2 available now
![](/galpreviews/SDC18610.JPG) ![hubs discs brake shields](/gallery/SDC18610.JPG) hubs discs brake shields
escort hubs and bearings studs and discs along with a pair of brake shields ( + a spare ) and bolts, discs never saw the road but are a bit pitted
will clean up fine £26
![](/galpreviews/SDC18626.JPG) ![classic mini rims](/gallery/SDC18626.JPG) classic mini rims
pair of Claasic mini 10" rims for trailer etc in good shape
£20
Collection from near Carlisle or Courier at buyers expense
plenty more where this lot came from
atb
Mike
