sdh2903
posted on 4/6/13 at 02:06 PM |
Fs, springs, mirrors, sierra column....
More bits and bobs for sale.
Brand new Faulkner 200lb, 8" long, 2.25" diameter springs. Only purchased from JJC at the start of the month, used for trial run in the
car. Cost me £50, looking for £35 delivered mainland UK. I will also give the buyer the receipt should there be any warranty issues.
Used 8" springs, 180lb, 2.25 in diameter, red, couple of bits of paint chipped here and there, unknown manufacturer. £20 posted.
Few bits left from my previous thread:
R1 mirrors (not genuine Yam), used for 1 run out, they may look back to front as I had the mounts apart and only slaved together for a pic. £20
posted
Remains of a sierra column £20 posted
Brake flexy pair. Orig supplied by russbost, end to end length of 19.5", m10 x 1.0 bulkhead fitting to M10 x 1.0 swivel fitting. New only used
in mock up (have had fluid in them) no half nuts for bulk head end supplied. £20 posted.
SteveWallace
posted on 4/6/13 at 08:20 PM |
Are the wing mirrors IVA proof, if so, I would be interested.
sdh2903
posted on 4/6/13 at 08:36 PM |
I will check the dims tomorrow and report back
sdh2903
posted on 13/6/13 at 03:24 PM |
200lb springs now gone
welderman
posted on 13/6/13 at 03:35 PM |
180lb, 2.25 in diameter is that outside dia or inside, im not fully up to date with springs !
First dibs if they fit my car please
Thank's, Joe
I don't stalk people
sdh2903
posted on 13/6/13 at 04:17 PM |
Hi Joe they are 2.25 ID, 3 in OD.
Sorry for delay with reply about mirrors I got sent away with work last minute. The sizing is fine to meet IVA as long as you mount them in the right
place. Only issue is I can't see an E mark anywhere, I can't remember if its required or not. Anyway a couple of more pics:
[Edited on 13/6/13 by sdh2903]
welderman
posted on 13/6/13 at 09:54 PM |
Will measure my car tomorrow ta
Thank's, Joe
welderman
posted on 14/6/13 at 08:55 AM |
Springs are too big sorry
Thank's, Joe
SteveWallace
posted on 16/6/13 at 10:17 AM |
Hi, I'm having IVA paranoia at the moment, so I think that I will go for some that are E marked so that I am sure of meeting the standard (the
IVA manual does not exactly say e-marking is a requirement, but one of the back up EU directives does). Thanks for looking anyway, if I was post IVA
I would have had them as I like the look.
sdh2903
posted on 16/6/13 at 11:59 AM |
No probs.
For iva purposes just get a pair off russbost. They are cheap as chips and WILL pass the test. Only one hole to mount them too so if they happen to
fall off after you pass you can easily replace.
