Author: Subject: Garage Clear out
FuryRebuild
posted on 17/6/13 at 05:00 PM Reply With Quote
Garage Clear out
I have a couple of items no-longer needed. First off is a pair of Luke GMAx 2" 4 point harnesses in blue.
They're £140 a pair each from Tweeks, before you add postage on.
I'll happily take £99 for them all in, posted to the UK, or make me an offer.
Secondly, I have an evolution Rage 3 saw, still in its box. This is the saw that cuts steel/wood/plastic/fingers, anything and is favoured among builders here. It cost me £100, yours for £70. I've made 8 or 9 cuts only with this saw so it is totally as new.
The saw is of course heavy, so if you want me to post, then I will at cost and I'll quote you first or will give you the dimensions and weight and you can sort it yourself.
I'm also up and down the M4 corridor a bit, so we can meet anywhere along the M1 to Oxford, or the Oxford route to Bracknell/Slough. If you live near Warrington, I'm over there soon and can meet anywhere between Harrogate and Warrington and the outlying bits.
Mark
www.furyrebuild.co.uk
