Author: Subject: Electric reverse, complete kit.
40inches
posted on 17/11/13 at 06:35 PM Reply With Quote
I am taking it off the MK, hardly used it, perhaps 4-5 times in 1800 miles.
The whole lot will consist of:
Modified Starter Motor.
Spur gear.
Mounting bracket(weld on).
Fibreglass cover.
Switch panel, but without the starter button, these are £7.50 from CBS.
Complete wiring harness with all the connectors, fuses and relays.
All the nuts, bolts, screws, connectors that are needed.
The wires will be labelled with instructions for welding on the bracket, and lining up the motor and spur gear.
Prop Catcher
Prop Catcher
Reverse Switch Panel
I am not giving it away, spent too much time on it, so £250 delivered.
PAUL FISHER
posted on 18/11/13 at 12:09 PM Reply With Quote
You have made a great job of that switch panel.
[img]http:// Reverse Switch Panel
[/img]
40inches
posted on 24/11/13 at 10:54 AM Reply With Quote
SOLD to CosKev3
