end of build clear out
i have been digging all my surplus stuff to make some room and the good stuff im putting up for sale all free to pick up from exeter or pay P&P
1x full set of early suzuki hayabusa injectors with mounts and with some link pipes respaced to suit st170 manifold £40ono
i am told gsxr1000 are the same? (usualy £50+ on ebay)
early silvertop zetec 1800 ecu (pats bypassable), throttle body,plugs, idle valve and part modded inlet manifiold with injectors and fpr plenum to
make £offers
zxr636 38mm throttle bodies complete with injectors,rubber link pipes and tps, 2nd butterflies removed and holes pluged £50ono
zetec blacktop throttle body with tps and plug £offers
1.8 cvh flywheel reamed out bolt holes to fit zetec crank (lighter than 1.8 zetec) with almost new complete clutch and release bearing. fits zetec to
type9 with std clutch. you will need to fit 36-1 trigger wheel to front pully use this £offers and its heavy!
1.8 cvh ign control unit inc plug. free to a good home
new boxed ign coil (eletronic) for meny fiat,talbot,mazda,toyota,volvo bosch 0 221 122 005 or lucas dlb231 or dlb109
(talbot sunbeam and fiat x19) £5
