Nick DV
posted on 24/1/14 at 08:48 AM |
Exhaust Advice
I need to alter the position of the exhaust can, but I do not want to spend shed loads of money at the moment - and I can't find anyone local
that can build collectors!
The current setup is 4-2-1, but as I have a spare 4-1 collector and a local exhaust place have said they can easily bend and weld a single pipe
between the collector and the can, that appears to be my best bet.
Therefore, if I decide to go down that route, would I notice any difference in performance going from 4-2-1 to 4-1? I've looked at lots of BECs
and there seems to be plenty of them using both set ups! Confusing!!
Any advice would be gratefully received
Nick
"The force will be with you, always!"
40inches
posted on 24/1/14 at 09:00 AM |
I used the standard bike header, ZX9R, this is 4-1 also. No problem with ground clearance
![](/galpreviews/DSCI0477.JPG) ![ZX9R-E manifold](/gallery/DSCI0477.JPG) ZX9R-E manifold
Nick DV
posted on 24/1/14 at 09:06 AM |
That's a nice, simple set up
T66
posted on 24/1/14 at 09:24 AM |
Osprey exhausts made my collector. Top service - they also sell all the components you may need at reasonable cost.
http://www.ospreyexhaustcomponents.co.uk
Nick DV
posted on 24/1/14 at 09:30 AM |
That may be a solution, but I wouldn't know if the 4-1 or 2-1 collectors would match my primary pipes. If they did and I could weld .........
T66
posted on 24/1/14 at 10:38 AM |
They will modify anything to your spec, give them a call.
[Edited on 24/1/14 by T66]
loggyboy
posted on 24/1/14 at 10:44 AM |
Just out of interest, are those horizontal pipes linking the headers, or are they just bracing/support?
Mistral Motorsport
Nick DV
posted on 24/1/14 at 10:57 AM |
Thanks for that, and if I get stuck, I may well do
mark chandler
posted on 24/1/14 at 11:07 AM |
Do not expect any real performance gains, sorry.
The optimum header length needs to be around 24" + another 12" to the can from memory, whatever you do there will not be sufficient space
to achieve this while leaving the can on the side.
4:1 is tuned to max torque at certain rev range, 4:2:1 gives a wider spread of torque but a little less at peak, unless your exhaust is horribly
restrictive I doubt if you note any difference, it may even become slower the sweet spot closes up.
To toggle the peak point you shorten primaries to raise the rpm, so advantage then will be high in the rev range which is not where you normally drive
the car.
Nick DV
posted on 24/1/14 at 01:49 PM |
the car.
Thanks Mark. TBH I had a suspicion that this would be the case, and I suppose this is why I see as many BEC with a 4-2-1 set up as there are 4-1
Anyway, with the way I drive, I'll never notice the difference
[Edited on 24/1/14 by Nick DV]
40inches
posted on 24/1/14 at 02:07 PM |
This is the E series header, the link pipes improve mid range torque. It is a well tried mod on C series engines, apparently
the difference is noticeable, although I haven't used the C series header so can't say from personal experience.
