40inches
| posted on 28/4/14 at 01:09 PM |
Kliktronic gear changer
This is one of the early ones, I bought it new but the car was only IVA'd a year ago. So not had much use.
The mounting bracket is my own creation, and fits on the top rail of the engine cradle (MK). This may need a bit of re-jigging to fit.
You can buy a nice billet ally one from Kliktronic for around £80.
It comes as in the photos, with a 10mm shaft gear lever, this is set to give the correct 25mm travel on a ZX9R, but is adjustable for other engines.
I left the manual change on the car, hence the extra fixing bolt.
The sleeve on the actuator shaft sets the shaft at midpoint, and is removed before using
The paddle switches are from a Jag, and will fit a standard Momo etc; or multi PCD steering boss.
There is also a choice of spacer(if needed) of 25 or 35mm thickness.
£185 + postage.
  Prop adaptor fitted
[Edited on 28-4-14 by 40inches]NOW SOLD
capri_big_jim
| posted on 28/4/14 at 03:12 PM |
Pm sent.
Flick
| posted on 28/4/14 at 04:55 PM |
U2u
