pekwah1
posted on 8/10/14 at 12:22 PM |
Bolt too far into engine block?
Hi Guys,
I've been helping my mate with his Mondeo (because i have the same engine in my car).
He took a couple of bits off the side of the block (exhaust manifold, something at the bottom) and when he was putting them back on lost the bolts.
He decided to use whatever he had lying around (which i think were longer than standard).
There now seems to be an oil leak on the engine (which look suspiciously close to where he was working). Is it possible that by using longer bolts he
has effectively wound them in through the sidewall of the engine creating an oil leak?
I'm not really sure myself so didn't want to worry him too much at this stage, but thought you lot would probably know.
If this is the case, is there anything you can do about it?
Oh, and it's a 2.0 blacktop Zetec in an old curvy mondeo.
Regards,
Jenko
posted on 8/10/14 at 02:20 PM |
Honest answer...if it's an old mondeo, it's probably not worth too much...so, unless you suspect the bolt is blocking an oil way, you
could just leave it in situe. Im surprised the oil is managing to push it's way pased a tightened bolt, so worth checking for cracked block
around area. Other option is to remove bolt, and put in smaller (length) bolt with some gasket sealant. Only worry is if damage has pushed some bits
of metal into the oil way. Maybe do an oil and filter change at the same time.
MY BLOG - http://westfieldv8.blogspot.co.uk/
Dingz
posted on 8/10/14 at 02:54 PM |
Seem to remember in the head there are a couple which can break into an oilway, you will need to remove bolt and use a sealant on the thread. Problem
is the bit of metal that has been broken off is in the oilway somewhere, hopefully it gets into the sump and sits quietly in the bottom!
went on and on.
pekwah1
posted on 8/10/14 at 02:57 PM |
Thought that might be the case....
I'll tell him he's a plonk and to get some sealant!
pewe
posted on 8/10/14 at 04:24 PM |
Different engine (Fiat/Lancia twink) but a couple of the bolts around the engine mount deffo went into and through the crankcase.
IIRC they were a taper thread i.e. self-sealing but a threadlock sealant on standard bolts sorted the leak.
HTH.
Cheers, Pewe10
Tatey
posted on 11/10/14 at 09:58 PM |
He can put a copper washer under the head of the bolt/between whatever he has bolted to the engine if he doesn't have anu suitable sealant. I
know of one particular motorcycle engine which does this due to a poor design resulting in a tapping breaking through into the crankcase.
loggyboy
posted on 12/10/14 at 12:33 PM |
Reminds me of this thread. http://locostbuilders.co.uk/viewthread.php?tid=165239
Mistral Motorsport
