daniel mason
posted on 8/4/15 at 06:25 PM |
DTA s60 pro ecu and farringdon Dash logger and wideband 02 for sale
Due to a last minute rush to get out racing this year I'm not going to have time to fit my farringdon steering wheel dash/data logger or my DTA
s60 pro ecu. Both are used but perfect working order.
The steering wheel dash is an all in one F1 type setup with integrated led shift lights, can do oil and water temps (sensors included),speedo (sensor
included) volts,tacho, gear indicator (wires into vehicle gear pot) oil pressure, etc etc. It also comes attatched to a lovely momo steering wheel,
pre drilled for a 3 hole boss.and a lap timing kit which I can't verify works as I've not tried it.
This is a proper bit of kit which now retails at well over £2k I think and comes with the farringdon data logger for those that wish to collect data!
This is the dash used in the high end radicals you may have seen on youtbe etc!
After £800 posted for this
Also have a dta s60 pro ecu which is not needed as I'm fitting the mbe 9A8 and 995 dash to get it up and running. Mapped for a k6 gsxr1000 and
could include loom if needed depending on whether or not it gets grafted into the mbe harness!
Will take offers on this but nothing cheeky guys. These are high end units also and retail at around £850 with no dta plugs or harness
I do have a Nice looking wideband O2 kit and sensor as well but can't remember what make it is at moment and my cars away having some prep done.
I can find out if needed. It's again high quality kit and was running a gsxr1000 turbo motor previously. Offers will be considered on this
too.
All items available as of next Saturday when I eventually get Round to collecting the car! Thanks
daniel mason
posted on 8/4/15 at 06:32 PM |
Dash Is now produced by stack and can be found on demon tweeks site at £1849 excluding vat. Momo 12c steering wheel included, Motorsport,dash
displays, stack steering wheel display on Web site
SPYDER
posted on 8/4/15 at 06:34 PM |
U2U sent re. Wideband.
daniel mason
posted on 8/4/15 at 06:39 PM |
Replied
