Author: Subject: Sierra/granada 7.5 LSD diff 4.21
craig5
posted on 7/7/15 at 11:15 AM Reply With Quote
The above diff for sale ideal for sprints/hillclimbs in perfect wôrking order £200 :-) so a bargain
wylliezx9r
posted on 7/7/15 at 11:28 AM Reply With Quote
Could be interested depending on how easy it is to exchange with a 7" bolt on shaft LSD ?
George Best
craig5
posted on 7/7/15 at 11:38 AM Reply With Quote
I've just got to a 7" diff 3.62 it's has p100 connections on for 7" lobros
mcerd1
posted on 7/7/15 at 11:45 AM Reply With Quote
depends on the size of your chassis's diff mounts...
some chassis are made wide enough to fit either type (using bigger spacers for the 7" diffs) other chassis may need a bit of work to make the bigger diff fit
the driveshafts may be ok (you'd need to check the lengths anyway) but it really depends on the type of flanges that are fitted to the diff
your current 7" diff should have the 100mm CV joints - the 7.5" can be the same, but Sierra Cossie ones had larger 108mm ones
[Edited on 7/7/2015 by mcerd1]
craig5
posted on 7/7/15 at 11:48 AM Reply With Quote
It's fitted with 100
craig5
posted on 7/7/15 at 11:50 AM Reply With Quote
and no spacers where needed when I swopped over it was straight swop
wylliezx9r
posted on 7/7/15 at 12:26 PM Reply With Quote
Did you have to modify the prop shaft ?
George Best
craig5
posted on 7/7/15 at 12:36 PM Reply With Quote
No nothing just had to locktite everything
wylliezx9r
posted on 7/7/15 at 01:00 PM Reply With Quote
So I think I would need new mounts going from 7" to 7.5 " ? Unfortunately I cant find anybody who manufactures them. Does anybody have any ideas ?
George Best
craig5
posted on 7/7/15 at 01:44 PM Reply With Quote
New mounts? what are you running now?
craig5
posted on 7/7/15 at 01:52 PM Reply With Quote
http://pages.ebay.com/link/?nav=item.view&alt=web&id=261952785261&globalID=EBAY-GB
craig5
posted on 7/7/15 at 01:53 PM Reply With Quote
If you have 100mm lobros they will fit
wylliezx9r
posted on 7/7/15 at 01:54 PM Reply With Quote
I have 100mm Lobros, I'm talking about the chassis mounts.
George Best
craig5
posted on 7/7/15 at 01:59 PM Reply With Quote
Only diff is 7" u need long bolt and nut and bolt to attach and on the 7.5" u can just use short bolt as the end is threaded
CosKev3
posted on 7/7/15 at 03:06 PM Reply With Quote
Craig your confused!
Most cars don't use a cradle system like yours to hold the diff, the chassis is built for a certain size diff.
so if the chassis is built for a 7 inch diff a 7.5 inch diff will be half an inch to wide to fit between the mounts, so it won't fit without chassis mods (ie cutting off existing mounts and welding in new ones)
If a chassis is built for 7.5 inch diff its easy, you just use spacers to allow a 7 inch diff to be bolted up correctly.
craig5
posted on 7/7/15 at 03:19 PM Reply With Quote
I can feel a group but coming along here then lol as I could replicate my craddle for anyone
mcerd1
posted on 7/7/15 at 06:43 PM Reply With Quote
^^ I think we need some pics of your setup
craig5
posted on 7/7/15 at 06:55 PM Reply With Quote
mcerd1
posted on 7/7/15 at 06:56 PM Reply With Quote
^^ what you say is true, but eh width of the mounts isn't exactly 7" or 7.5" - those numbers only really refer to the size of the crown wheel inside and its more of a coincidence that the mounts widths are approximately the same give or take a few mm
(ie don't go chopping exactly ½" off the mounts and expect it to fit)
craig5
posted on 7/7/15 at 06:59 PM Reply With Quote
didnt have to as front craddle has pre drilled running holes to allow small movement too forwards or backwards
mcerd1
posted on 7/7/15 at 07:09 PM Reply With Quote
^^ most chassis are quite a lot different to yours
the dax rush ones are integral to the chassis with enough room for 7.5" or 7" diffs and don't use the rear mount
the mk indy is like this:
the mnr vortx is like this:
and so on....
CosKev3
posted on 7/7/15 at 07:22 PM Reply With Quote
(ie don't go chopping exactly ½" off the mounts and expect it to fit)]
99% of people on here know that, we weren't talking about someone cutting up a diff, just trying to explain in a easy to understand way why a 7.5inch diff wont fit in a chassis built to take a 7 inch diff.
CosKev3
posted on 8/7/15 at 07:25 AM Reply With Quote
My chassis in the pic above, built for a 7 inch diff so would need new mounts welding in to take a 7.5 inch diff.
craig5
posted on 9/7/15 at 05:56 PM Reply With Quote
Now sold
