Chris_Xtreme
| posted on 9/10/15 at 03:06 PM |
Rover V8 Parts for sale since I am now EFI
Since I have EFIed the RV8 I have the old parts up for grabs.
I haven't looked too hard yet into prices etc or what postage would cost but thought I would put the list up here first and see if there is any
interest.
So
1) set of Yellow Mallory 8mm HT leads - working perfectly before my ugprade.
2) set of black 7mm HT leads - came of a unknown state engine I bought (sizing engine) .. was meant to be a runner - I have no idea
3) Carter LP fuel pump. I thought it was iffy as it knocked a fair bit and was noisy. However replaced it with a different one and it is just as
noisy - must be where it is on the car. Was fine before the upgrade.
4) Rotor Arm STC1857G -- looks new. (a spare that came with the car)
5) Dizzy Cap - looks like light use (a spare that came with the car)
6) small catch tank ~15cmx5cm was plumbed in to the top of the rocker covers, really too restrictive for a v8.
7) what looks to be a stock RV8 oil cooler take off (off sizing engine)
8) unopened durite water temp gauge
9) Edelbrock manifold, Holly Carb, air filter (all functioning fine pre upgrade)
10 ) Luminition ignition AB 44790 22127 9311 (functioning fine pre upgrade) (I've thrown the coil as it got left out side in the rain)
11) not related to v8, but a clutch cable QH FKC1138 (Ford)
12 ) Another dizzy cap, was running fine before upgrade.
13) RealSteel GM style PCV valve 90 degree pipe was working fine before upgrade.
Link to pictures of everything.
https://goo.gl/photos/r3fy3dquan9aZbX67
Any interest let me know and we can come up with a price / postage.
If there is anyone after the lot to go on a RV8 all the better
thanks, Chris
marcjagman
| posted on 9/10/15 at 05:31 PM |
how much for the yellow leads, manifold and carb please?
Chris_Xtreme
| posted on 9/10/15 at 07:48 PM |
just looked them up on the handover sheet the builder gave me.
Edelbrock 4 Barrel Inlet Manifold from Real Steel . It does have an extra smaller hole tapped in it for a water sensor for an electric water pump
and it is a Holley 390CFM. with most of a trick kit. ( I replaced the fuel bowl bolts and gaskets and needles)
with the HT leads £200 posted ?
I'd thow in the other little rv8 spares and filter too if you like as they are probably only worth a few quid.
Chris_Xtreme
| posted on 13/10/15 at 03:39 PM |
bump
any interest?
Irony
| posted on 14/10/15 at 07:28 AM |
7. What is this oil cooler takeoff, any piccies?
Chris_Xtreme
| posted on 14/10/15 at 07:59 AM |
https://lh3.googleusercontent.com/bHjS4hFihbi_jP8DcLj7EEGBCgA6QC4hsQZ8FLKx6YDyd5upyRi8JiTNBhkLsrMyBAubnOlQ4jGXrMwVtCKeUJ5_w7iYDCpOA6ov9NSsadm
49fjkwU03VkpGGP_-ECMcVfDbeq-3xic5nmlGBAT7Hz8A5XfXCqYiLzuOIJogSx9LRTJxz0apA7KB8F3Pro7Wi5yOo16MbiM1Hf-mJ4xH7GxJDDUzJJdrsaJgT9eJVOlKsD5yoKfWQe6BoNSbYadX0
ur7_aRNys0_EV0CVnVpmHf_opBcObYB7edENutlJphn4k3ActDopMEGYqTb9wMX-4TQaX3PDc7PEScAjDfFSPfH0f48nAidE8aDo-2qqHrGrgIqoSG6NNXiVVWphtOamxgIbF9ZqYKaPQRdMACGw4H
XYLXi-c7TAqcn9PR8_m5zlXiCCpFtOSqXgCH_JYkadM3Ri--ww05X5L5hdBshuqb104y8IdH1cUTHVIB8p0ylwRCkh-W5UXGyELfLyk0BBoM5lXfKGFS6StqebrOFoS6t3EmgB_9WHOSqN_Us0NY=w
1268-h714-no
Irony
| posted on 14/10/15 at 12:01 PM |
How much?
maesglas55
posted on 17/10/15 at 08:24 PM |
Hello is the carb and the manifold still available and if so got a mate looking for one so please could you not sell it before talking to myself.
David Rees.
Chris_Xtreme
| posted on 18/10/15 at 06:45 AM |
Hi David,
Nothing has sold yet.
Chris
maesglas55
| posted on 18/10/15 at 10:10 AM |
Hi Chris
Just had a word with my mate and he wants it for 200 quid if it comes with the leads and all the bits like you offered the other guy. If you are happy
with that consider them sold just let me know how you want to be paid.
David Rees.
Chris_Xtreme
| posted on 19/10/15 at 01:44 PM |
Some parts Sold:
interest.
So
1) set of Yellow Mallory 8mm HT leads - working perfectly before my ugprade. --- SOLD
3) Carter LP fuel pump. I thought it was iffy as it knocked a fair bit and was noisy. However replaced it with a different one and it is just as noisy
9) Edelbrock manifold, Holly Carb, air filter (all functioning fine pre upgrade) -- SOLD
thanks, Chris
