Author: Subject: Lots of CBR900 parts! clearout
Matt21
posted on 10/10/15 at 06:16 PM Reply With Quote
I seem to have acquired a lot or cbr900 parts (919cc), so I am having a clearout
Starter motors x2 £15 each
Cylinder heads, I have two, one from a 1996 and one from a 1997, both with cams. £60 each
Exhaust manifold for a kit car, stainless steel. Requires one of the ends welding. £70
2 blocks/casings, one is a 1996 and the other is a 1998. both were running engines, no bearings included just bare casing £100 each
2 gearbox internals, all gears, selector and all associated parts included. £80 each
Various engine covers, clutch, crank, generator etc let me know which one your after and I'll give you details and a price
2 oil pumps, both fully functional when removed. £10 each
A cylinder head cover, painted green (could do with stripping and sorting though!) £20
Complete air box with a filter, never used by me but the filter doesn't look that old. £15
CBR900 radiator, has a couple of bashed vanes but no holes. £50
I also have 2 shortened sumps, you will be required to shorten the oil pick up and make some pins on it so it cant fall out of its holder, and file a couple of slots in the end pressure relief for it to fit. £60 each
I can also make gasket sets, let me know what you require
all prices are excluding p&p
