Pat_T
posted on 25/10/15 at 07:56 PM |
Projector lights, gear linkage shaft & NACA ducts for sale
Having a clearout as my build is coming to an end and also may be moving house shortly.
Pair of brand new Projector headlights. Very clever as combine main and dipped beam into one unit using a single H1 bulb. They do this with a solenoid
controlled shutter. Very nifty! Only selling as decided not to fit headlights to my track car in the end. No bulbs incldued but H1s are cheap. Also
HID kits are available to suite these, and I think people have had no problem passing SVA/IVA/MOT with them.
Similar/ same? as Russbost sells:
http://furoreproducts.co.uk/projector-headlights/39-combined-dip-main-beam-projector-headlight.html
£45 posted
Gearchange linkage shaft.
Believe it or not this shaft is actually from a 1988 EuroBrun ER188 F1 car!! (yes, I had to google it too!)
Complete with two sealed heli joints, look to be brazed rather than welded to the shaft to ensure against cracks from vibration.
Will confirm distance centre to centre of joints tomorrow.
![](/galpreviews/10991386_721196023066_1895164525496070583_n.jpg) ![Description](/gallery/10991386_721196023066_1895164525496070583_n.jpg) Description
£20 posted
2x plastic NACA ducts. Some small cracks in the plastic but not structural and the parts are perfectly serviceable.
Pictures and dimensions to follow.
£13 posted each
cheers,
Patrick
www.instagram.com/patroclueus
ceebmoj
posted on 26/10/15 at 06:41 AM |
Im intrested in the ducts dependant on size. Please can you mesure them?
Rossmcleod
posted on 26/10/15 at 07:42 AM |
Any pics of the ducts
Target : 540 BHP per ton :-)
Pat_T
posted on 26/10/15 at 06:02 PM |
Ok NACA ducts have 155mm wide openings, about 30mm deep, and 210mm total length.
Gearchange shaft is ~453mm from the centres of the heli joints.
cheers,
ceebmoj
posted on 26/10/15 at 07:50 PM |
I will take the ducts please
Pat_T
posted on 26/10/15 at 08:38 PM |
Ducts sold
Pat_T
posted on 31/10/15 at 02:09 PM |
bttt
bump
£15 posted gear linkage shaft
£30 posted projector lamps
CC Cyclone
posted on 31/10/15 at 07:02 PM |
Hi what diametre are the lights please? Outside diametre of black housing is the bit I need to know. Thanks.
Pat_T
posted on 1/11/15 at 04:07 PM |
Hi, the outer diameter of the black plastic housing is exactly 70mm
thanks,
Pat
[Edited on 1/11/15 by Pat_T]
Pat_T
posted on 7/11/15 at 07:08 PM |
Bump.
Offers for the lights and shaft? Need them gone..
Pat_T
posted on 8/11/15 at 08:44 PM |
lamps sold.
just the gearlinkage shaft remains!
cheers
