CosKev3
| posted on 8/1/16 at 11:08 AM |
Acumen DG8 gear indicator
Acumen DG8 gear indicator with blue display.
Excellent condition complete with fitting instructions , £35 posted to UK addresses.
daniel mason
| posted on 8/1/16 at 01:31 PM |
Is it universal fitment? Are they quick and reliable? I would like one for my R1 engined Jedi! I assume they wire Into the gear pot Rather than ecu?
CosKev3
| posted on 8/1/16 at 04:09 PM |
Which R1 engine do you use?
I'll check the list of bikes.
It uses your speed sensor,tacho feed,and you neutral switch.
daniel mason
| posted on 8/1/16 at 04:14 PM |
I've got a hybrid 4xv/5jj race engine on flat slides. But it has an AIM data logging dash and pneumatic paddle shift which both use tacho feeds.
The gear pot wires have been cut short as has neutral switch.
CosKev3
| posted on 8/1/16 at 04:23 PM |
Where is the gear pot sensor on the early R1?
Can't picture it on mine that's all!
I would guess you would need to re - wire your neutral switch to fit this,and is your speeds sensor still fitted?
daniel mason
| posted on 8/1/16 at 04:31 PM |
Speed sensor is in front wheel wires to the data logger. Gear pot still fitted but wires cut short. There's enough to solder connections to
extend
CosKev3
| posted on 8/1/16 at 05:48 PM |
Perhaps contact Acumen and find out if your speed sensor is compatible?
I would guess your standard speeds sensor is still in the engine casing?so you could re - wire that up to use if your sensor on wheel is not
compatible.
CosKev3
| posted on 21/1/16 at 10:43 AM |
Still for sale
CosKev3
| posted on 22/3/16 at 04:12 PM |
Open to offers
CosKev3
| posted on 4/8/17 at 08:48 AM |
SOLD
