Author: Subject: Front wheel arches
Gasgeek
posted on 14/4/16 at 10:53 PM Reply With Quote
Front wheel arches
Hi
Can any body recommend a good adhesive to bond my wheel arches to the brackets
my old ones where bolted on that's cause cracks and crazing in the gelcoat.
ReMan
posted on 14/4/16 at 11:21 PM Reply With Quote
sikaflex
Is most commonly used
Very sticky and flexes, make sure and key well with super rough sandpaper on the wings and stays
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
CosKev3
posted on 15/4/16 at 07:20 AM Reply With Quote
As above,any polyurethane adhesive will be ok.
Tiger Seal is quite a common,but expensive one in motor factors.
If your brackets are flat bar drill some holes in them for the adhesive to go into,as well as keying and degreasing both surfaces
[Edited on 15/4/16 by CosKev3]
Gasgeek
posted on 15/4/16 at 07:58 AM Reply With Quote
Wheel arches
Thanks for the advice guys
benchmark51
posted on 15/4/16 at 08:01 AM Reply With Quote
That's how I do it, but I weld plate on to the bracket and grind it flat to make the adhesive 'footprint' bigger
mcerd1
posted on 15/4/16 at 08:42 AM Reply With Quote
Würth 'bond and seal' is another decent PU
Most decent builders merchants should have one of these or a good alternative
[Edited on 15/4/2016 by mcerd1]
Greenie
posted on 15/4/16 at 07:02 PM Reply With Quote
I have just secured mine with sikaflex, works a treat, but said, make sure the brackets are clean and rough up fir a good key.
twybrow
posted on 15/4/16 at 08:06 PM Reply With Quote
I glassed on some captive nuts (rivnuts used like Big Heads) which means I can unbolt my arches in a minute or so. Very handy and secure.
