flanders
| posted on 19/10/16 at 03:29 PM |
ZX9r conversion /install package £1000!
Up for sale soon will be my zx9r set-up from my MK, ready just to drop in and go!
C2 engine, cradle, manifold, loom, filter, braided fuel line, fuel pump, fuel tank, Shortened and baffled sump, new Kawasaki clutch and updated
clutch springs. pretty much everything you need to install the engine
very strong engine with no issues. im changing to a ZX12r engine setup.
There may also be other parts (sprocket adapter, prop, oil cooler, pipework etc depending on what i can reuse). If anyone is interested let me
know.
Hopefully the engine will be removed in a week or so and ill know exactly what is available.
Located in fife, Scotland. I can send on a pallet no problem.
£1000
[Edited on 19/10/16 by flanders]
[Edited on 21/10/16 by flanders]
flanders
| posted on 19/11/16 at 09:18 AM |
Update. Engine is removed ready to go.
ZX9R C2 engine (new Kawasaki clutch, updated Barnet clutch springs, 13k miles)
cradle
Jetted carbs and sausage filter
Prop adaptor
Shortened sump and oil pickup
loom (will need modified to your application) and CDI
Fuel pump
Coil sticks
Plastic fuel tank
Nearly new Regulator rectifier (to be soldered in)
I will split if there's interest in specific parts
£850
flanders
| posted on 28/11/16 at 11:24 AM |
Still for sale -
Zx9r engine with new Kawasaki clutch, updated Barnet clutch springs, 13k miles - £500
carbs and pipercross filter (set up and jetted to run in car) £200
coil sticks - £40
Sprocket/Prop adapter- £35
Wiring loom & CDI - £20
New regulator/rectifier (needs to be soldered in) -£50
Engine cradle for an MK - £60
Shortened sump and shortened pick-up - £65
flanders
| posted on 18/12/16 at 10:14 PM |
Cradle now sold
Still got the engine etc
