Author: Subject: FS: VDO \ smiths dials, GTiR back plate, Pipercroxx airbox. Starcom intercom
bi22le
posted on 13/1/17 at 05:16 PM Reply With Quote
I have a few bits that I need to loose as they are taking up space.
I have not thought of prices so if you are interested then PM me and we can talk monies.
I can post but if you collect I will make you welcome with tea and biscuits!
Dials can be sold separately or as what you want. Note damage on the speedo and rev outers, others are very good IIRC. Senders may be available at a later date once I get my other dash in.
dash3
dash3
temps and pressures
temps and pressures
fuel dial
fuel dial
oil pressure
oil pressure
rpm dial
rpm dial
speedo dial
speedo dial
A very robust 4age to pipercross backplate manifold. This is hand made and welded. Finished in black crinkle paint and looks the very nice when fitted. I dont have the filter anymore but any PX600 will fit. I was going to use this for supercharging but have gone a different way to use space better. The length of runner and turned ends are optimised for engine and my engine was very quick with this fitted.
4age man1
4age man1
4age man2
4age man2
4age man3
4age man3
Pipercross air box. This is new and unused. I trial fitted it but it has done 0 miles.
pipercross air box
pipercross air box
GTiR plenum back plate which may be of use to someone. I bought a whole one but am using the front \ top piece.
gtir baCK1
gtir baCK1
gtir back2
gtir back2
Starcom Advanced Intercom. THis has worked wonders for me over the years. With 3.5mm jack in for music and auto background cancel for clearer chats. This works well when doing 70mph on the motorway when you both have crash helmets on. I have used this for 2 X ring trips and many morning runouts with the wife. It comes with the box 2 X coli extension leads (not shown) and 2 X helmets sets. Read the reviews this is a nice bit of kit. 2nd hand well used but working when removed.
starcom1
starcom1
starcom2
starcom2
Please read my ring story:
Fandango
posted on 13/1/17 at 06:32 PM Reply With Quote
Interested in the tacho, just need to check it is correct for my setup.
What is the diameter pls, and what ignition system have you used it with?
Cheers Carl
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me." Hunter S Thompson
Norfolkluegojnr
posted on 13/1/17 at 08:03 PM Reply With Quote
Is the speedo mechanical or electric pick up?
And what diameter? Interested in that and tacho if they fit!
Dick Axtell
posted on 13/1/17 at 08:21 PM Reply With Quote
PiperX Airbox
Am interested in your P/cross airbox. Please advise length (will it fit over the 600 backplate?), and how much.
Charlie_Zetec
posted on 13/1/17 at 09:39 PM Reply With Quote
Potentially interested in the Starcom intercom....
bi22le
posted on 14/1/17 at 01:15 AM Reply With Quote
Thanks for all of the interest. I have been out all evening and only just got in.
I will reply to your messages and U2U tomorrow.
bi22le
posted on 14/1/17 at 02:35 PM Reply With Quote
I think its 80mm and I am running ot with omex710. I guess it will be taking the feed staright from the ecu.
Cheers Carl
bi22le
posted on 14/1/17 at 02:36 PM Reply With Quote
Again I think its 80mm with electronic pic up. I may have the sensor for sale as well.
bi22le
posted on 14/1/17 at 02:38 PM Reply With Quote
It is designed to clip to the 600 backplate. This means that you remove the sausage filter and this replaces it.
Your 2nd dibs as someone who is also interested me U2U me yesterday.
bi22le
posted on 14/1/17 at 05:51 PM Reply With Quote
Manifold and GtiR back plate now on ebay
Toyota 4age throttle bodies to Pipercross 600 back plate manifold
Nissan Pulsar GTiR Inlet Plenum backplate
No Reserve!!
[Edited on 14/1/17 by bi22le]
Fandango
posted on 15/1/17 at 07:14 AM Reply With Quote
Ok thanks for that.
Is there a visible part number on it, and could you u2u me a price, including carriage?
Cheers Carl
Norfolkluegojnr
posted on 15/1/17 at 10:53 AM Reply With Quote
Ah ok - I'm after a mechanical one. Let me know if you discover otherwise I'll happily have them!
bi22le
posted on 15/1/17 at 11:01 PM Reply With Quote
I have had loads of interest for the dials. They are not s,old yet but doubt I will get to the end of the queue before they are sold!
bi22le
posted on 16/1/17 at 08:23 PM Reply With Quote
Again, a lot of interest in the Pipercross airbox. Its not sold yet but I have a good few people to offer it to.
GTiR is on ebay as is the 4age to pipercross manifold.
bi22le
posted on 21/1/17 at 06:33 PM Reply With Quote
GUTTED!!!
Both the 4age manifold and GTiR back plate sold on ebay for 99p each!
Im glad the postage was honest and not reduced to help a bidding war!
